(1) 2 3 »
Thanks
From Dubbo NSW Australia
G'day
Thanks for the info.
I searched on electronic ignition and didn't find anything.
I will let you know how we get on.
Regards
Chris
Posted on: 2003/11/17 7:50
Re: Thanks
From newcastle, NSW
HOWDY PARTNER! i have an electronic ignition, its out an N13 pulsar. all you have to do is change over the bottom gear with a 1200 gear and then modify the base plate(advance and retard plate) and get a dizzy off a pulsar or bluebird and modifiy the wireing so that you can get rid of the ballast resister mainly the main ignition wires. i can give you a detailed description if you i want. Does any one disagree? Please send your critisims i like being critsized,Thats how you get thing right!well thats what i think any way!
Posted on: 2003/11/17 8:02
Re: Thanks
G'day
Yes please, any help would be appreciated.
Posted on: 2003/11/17 8:11
Re: Thanks
From Adelaide, Aust
Steveo you smell Theres your critisism now down to business, I would love to get a detailed discription of how to change to electronic dizzy. Just email it to me if possible. Thanks
Posted on: 2003/11/17 9:57
It's a way of life
Re: Thanks
Steveo I agree with everything you have said but one thing I would like to point out is when swapping the 1200 gear onto the bottom of the N13 distributor you actually have to drill a new hole in the N13 distributors shaft for the locating dowel of the 1200 gear. This is done so the shaft will be the correct length and so that there is no play in the distributor shaft.
( It's straight forward and easier to understand when everything is in front of you.)
Cheers Steve.
Posted on: 2003/11/17 10:17
Re: Thanks
Quite a regular
From Greece Athens
I did the same with my b310 but i took an electronic ignition from a honda accord and it's exactly the same.
Posted on: 2003/11/17 10:57
Always Tuned
Nissan B310 '81
Re: Thanks
OK Pantel,..... now you have to tell us ALL about it, & i want DETAILS.
Chris
Posted on: 2003/11/17 11:03
Re: Thanks
From Adelaide, Aust
Exactly the same as what? the pulsar or the A series engines?
It's a way of life
Re: Thanks
Quite a regular
From melbourne
Yea I've done the pulsar conversion aswell and would recomend it, but............. please make sure you use the right coil for it.It must be high energy and the best is one of the pintara twin spark coils.I found out the hard way that new High energy coils(t shapes ones) are no more than paper weights,good old original datto gear wins again
Posted on: 2003/11/17 11:10
Re: Thanks
Instead of searching for electronic ignition, try these searches:
electronic dizzy
electronic distributor
pertronix
Posted on: 2003/11/17 20:50
(1) 2 3 »
