navara diff
From Rosewood, QLD
has anyone shortened one and used it on their datto? im assuming it will be similar to a hilux diff in regards to strength and gearing but i may be wrong
Posted on: 2010/5/7 1:06
1971 B110 sedan project.
2012 Nissan Micra daily.
Re: navara diff
From Geelong, Vic
pretty sure they run h190s, same as series 3 bluebird diffs
not the most common diff to run in a 1200 as they are a bit more expensive to cut to to suit a 1200 in regards to the axles.
i wouldnt mind getting one(h190) and using a 1500 alloy pumpkin on it and replacing the BW diff thats in my car at the moment. as they are so much better looking and a little lighter i imagine, mainly better looking
Posted on: 2010/5/7 2:18
Re: navara diff
From Rosewood, QLD
yeah sweet... should be picking up a wrecked nav to finish off my kingcab for rego anf was thinking of using the spare diff for my 1200
Posted on: 2010/5/7 2:55
Re: navara diff
From Townsville, Qld
Those Borgies look terrible I agree
Posted on: 2010/5/7 5:58
Re: navara diff
From Sydney
I own an 03 D22 Navara 4x4 and it runs a H233 LSD diff assembly. They are enormous and are way bigger they the H190. So im guessing that the diff you are looking for is out of a D21 or earlier.
benny
Posted on: 2010/5/7 7:37
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: navara diff
From Christchurch NZ
some navaras run what they call a C200. AFAIK, these are a solid rear axle version of an R200 diff. I bought one. (cost me $200) PUlled it down, and found it was a clutch lsd. I wound up on selling it. (I bought it on a whim) Had nice big juicey axles. Plus I read that the gizzards are interchangable with R200's too.
Posted on: 2010/5/7 10:43
Forced Induction!
