« 1 (2) 3 »
Re: Thanks
From newcastle, NSW
when you buy a dizz you will notice that there are two main wires, Black\white and blue,Quite simple really,b\w go to the positive(+) and blue goes to negitive(-) and what i did was connect an earth wire from the vacumm advance to the tappet cover. I use a bluebird coil or you can use an ET pulsar coil(i think?) any other questions? don't hesitate to ask. i forgot to mention drilling a hole for the gear,SORRY i'm getting a bit forgetful in my old age!
Posted on: 2003/11/18 7:01
Re: Thanks
Quite a regular
From Greece Athens
My old motor is an A12.I say that because now I'm fixing an A14.Well with my old motor i had problems with my ignition and i didn't know what to do.One day I saw a honda accord '81 and the distributor was the same,so I decide to take it.My engeneer told me that we had a problem with the shaft because it was longer and the gear was diferent,but he told me not to worry as we had my old distributor.So we took the old shaft and gear as it was and put it to the new distributor. Then we install the little box with all the wires and here we are without problems any more!!!
Chris is it Ok?
I hope it's the answer you want.
I will try to take a foto to show you
Posted on: 2003/11/18 8:04
Always Tuned
Nissan B310 '81
Re: Thanks
Pantel, my friend, thats EXACTLY what we want & i thank you.
Does the Honda engine have an identifying code. I do not know much about Honda's, but diferent makers used diferent engines in some cars for diferent markets around the world, Perhaps Honda did too.
Posted on: 2003/11/18 10:41
Re: Thanks
Quite a regular
From Greece Athens
No I dont' have an identifying code but I'II try to find one.I'm going to ask the store i took it and I hope to tell me.Anyway I didn't know the code of the engine but optically it was exactly the same as our's,the same size,the same wires all of it.!!!
p.s it's a FWD model, the first with electronic ignition.
Posted on: 2003/11/18 12:02
Always Tuned
Nissan B310 '81
Re: Thanks
Quite a regular
From Greece Athens
Hello Chris.
I found for u the identification of the Honda.
It's an EL 1600cc Honda Accord '82.
I hope I'm helping u with this
Cheers
Posted on: 2003/11/27 10:10
Always Tuned
Nissan B310 '81
Re: Thanks
Pantel, you're a legend & i thank you. I would like to think that this info helps more than just me though.
Thanks again
Chris
Posted on: 2003/11/27 10:29
Re: Thanks
Quite a regular
From Greece Athens
Ok sorry. I ment all of u
Thanks for your nice words Chris
realy thanks
Posted on: 2003/11/27 11:04
Always Tuned
Nissan B310 '81
Re: Thanks
From Canberra, Australia
The next time that someone on this site decides to mod a distributor. Can they please please please please please take pictures of each step and make up a website or word document with the pics in and each step?
Cos that would be super!
Posted on: 2003/11/27 13:38
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: Thanks
From Perth, West Aussie
wiring? Ballast resistor? I thought they didnt use a resistor because they are electronic?
now i'm confused hmm...
p.s. has anyone got that bit of the pulsar wiring diagram?
Posted on: 2003/11/27 14:01
Re: Thanks Electronic Ignition
From Newscastle, Australia
I want to say Im going to keep this thread going on the home page until WE GET PICTURES!!! Im with you Lobster. Hopefully Chris will get pictures on the site for us.
Posted on: 2003/11/27 23:44
« 1 (2) 3 »
