Must read ,A15 but different !!!!!
From mandurah
i came across a very strange A15 today and it had the dizzy on its side in the block ,the fuel pump on the wrong side so i dont know what it would be running of ,and some other strange stuff
ok so far all i can remeber is
head bolts on the outside of the rocker cover (like a mini)
datsun rocker cover
A15 stamped into the same place on the block as an A12
fuel pump on the manifolds side of the motor ? strange i know !
dizzy was almost completely horizontal to the block
funny lookin water pump ,it had its own port
looked to be A12/14,15 inlet manifold with 'japan' stamped on it
looked to be a standard 1200 carby
realy wide head
would this motor maybe be a morris or mini or something with a datto rocker cover ?
could it be worth money or just be a waste of time ?
Posted on: 2010/5/19 14:28
Re: Must read ,A15 but different !!!!!
You sure it was not a J15?
They are similar and easy to mistaken.
Posted on: 2010/5/19 15:06
From Perth
Look abit like this ?
Posted on: 2010/5/19 15:31
Yes. It is worth heaps of money. Heaps and heaps.
Posted on: 2010/5/19 16:24
From mandurah
yes thats it !! are they realy worth any good money ?
Posted on: 2010/5/20 10:00
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Invercargill, New Zealand
Nah - they are povo as. Good to power a hydraulic woodsplitter that needs to run at 1500rpm all day but if you want to put it in something with wheels then the world may stop in it's orbit and go backwards.
Posted on: 2010/5/20 10:08
From mandurah
oh so they are more an industrial motor rather than a good base for a street motor
Posted on: 2010/5/20 10:10
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
Quite a regular
From Sydney NSW
That exhaust header is a smart piece of work.
Posted on: 2010/5/20 10:11
From Rosewood, QLD
shazam!!!
Posted on: 2010/5/20 11:20
1971 B110 sedan project.
2012 Nissan Micra daily.
From brissie
was gonna say they use them in forklift applications.
Posted on: 2010/5/20 12:36
A12,4spd, mild cam ,head work, mags.
