What paint did you use to paint your Ute tray?
From Adelaide, South Australia
Hi Guys & Girls,
Ive just rust proofed my tray and I was wondering what paint you guys are using to paint the tray. I need it to take a bit of ware, thats why I wont be painting it the same as the Ute its self.
Someone told me to use Bitumen paint, but Ive never used it before.
Any infomation would help.
Thanks
Posted on: 2010/5/24 7:06
Project: CA18 1200 Ute
Re: What paint did you use to paint your Ute tray?
From cranbourne, vic
after rust treating mine i hit it with 2k primer and 2k top coat (left over from another build), then i put "motorspay" ute liner over that, the first litre i used barely covered it.. and i didnt realise it came in a better colour, so i put on an extra litre in a lite grey (the rest of the ute is white), so far its lasted over a year but it does scratch off if you abuse it, but most of the time it goes back to the 2k top coat. but i dont use the tray all the often and mainly throw in tyres, rims, pit bike, bmx or parts from wreckers...
Posted on: 2010/5/24 7:39
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
From Mandurah, Western Australia
Personally would not use bitumen paint.
Seen a ute done with the spray on poly urethane ute liner and that looks sweet and wears well. No idea on cost though and you cant do it urself
Posted on: 2010/5/24 10:39
fibre glass?
steel checkerplate?
deck it out with wood.
go to clark rubber and get those foam/rubber pads and stick them down
http://www.clarkrubber.com.au/matting ... ring-vehicle-matting.html
Posted on: 2010/5/25 4:26
From Townsville, Qld
Yeah Ian had his sons utes done with Rhino lining ages ago, works a treat. I inquired about getting my ute done mabey 2 years ago and was told it would be at least $700. The prep for it is basically ensuring it is rust free and putting a decent primer onto the surface. They may do that part as well but I assumed that wasn't part of the price.
Posted on: 2010/5/25 9:56
Quite a regular
From Inner West Sydney
Hi,
When we did my son's ute we used some two part epoxy paint left over from lining a water tank where I work.
Applied with a foam roller (fabric one leaves strands in finish).Did the floor black and sides white.
No undy, straight on clean bare metal.It has a softer feel like all epoxy finishes but wears ok and certainly stops any rusting. He has a heavy rubber mat on the floor and I use the ute to transport machinery a bit.
Dulux Durebild STE.Don't know how small a quantity you can buy as you'd only need a litre or 2 and its an industrial product. We had 20 and 4 litre tins at work. H.
Posted on: 2010/5/26 0:09
Cheers for all the info guys, alot more options than I thought.
Posted on: 2010/5/29 7:10
