« 1 ... 4 5 6 (7) 8 9 10 ... 25 »
Re: 120y sedan SR20de.... Im now in control... i think....
From mandurah
wow the worked well what brand paint stripper did you use ?
keep up the good work !
Posted on: 2010/6/5 11:21
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Rosewood, QLD
looks like that paint on the roof was 2pak... acrylic is usually much much messier from my experience, 2pak comes off so nicely.
sweet build dude!
Posted on: 2010/6/5 11:30
1971 B110 sedan project.
2012 Nissan Micra daily.
From RAdelaide
Car is all original even down to the acrylic paint.
It's k&h paint stripper - the one with the pink label not the brown. i'll get the pt no in the morning for you if you like. The brown label is not as strong
Posted on: 2010/6/5 12:02
From mandurah
yea that would be great thanks !!
Posted on: 2010/6/5 12:04
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Albany, Perth Australia
man that is an awesome paint stripper. Last time i used paint stripper it just didnt work at all but if this stuff works i an gonna have to get some. Where did you get it from?
Posted on: 2010/6/5 16:03
1200 Smerf Mobile
From RAdelaide
Stripped the boot lit tonight when I got home from work and found a skin of bog. A elephant may or may not have sat on it at some stage.
May look for a reproduction or a better example of one, it's not ugly but the sheet is actually separated from the frame too.
The stripper is actually called "rapid paint stripper" pt no. RPS4 . (4lt)
Posted on: 2010/6/6 11:18
From Adelaide
Kristo! Coming along nicely.
The donation swaybar bolted in no probs, cheers.
I'm still fiddling with brakes and wheels.
Jake
Posted on: 2010/6/6 11:41
From RAdelaide
Cheers! Catch up for datsun beers soon, may need some more help getting this thing back to metal in time for the painter
Posted on: 2010/6/6 12:09
Looking great srb210. Great job on everything you have done so far. The motor come up a treat. Did you make a dessision on the diff? Keep up the good work.
Posted on: 2010/6/6 12:15
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
From RAdelaide
Yeah decided on a r31 shortened with kaaz centre
....how much work for s13 IRS i wonder??
Oh on the strpper you can order from any K&H dealer, look on k&h website for stockist in your state. Mine was from autobarn
Posted on: 2010/6/6 12:26
