« 1 ... 8 9 10 (11) 12 13 14 ... 42 »
Re: Project Drift coupe (AKA 1200 coupe )
From Albany, Perth Australia
yeah just take it all out and we can just fix everything
Posted on: 2010/6/8 15:35
1200 Smerf Mobile
Hey mate. I have a r31 fuel take in my ute project. Have you got this thing running yet and was it able to pump enough fuel with the standard internals? Also are you going to be using the case that goes half over your cam gears that your CAS bolts to?
Posted on: 2010/6/9 5:32
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
i wouldnt be too keen on running standard turbo coolant pipes behind the head... just a thought if u want a relatively simple drift car...
Posted on: 2010/6/9 7:08
From mandurah
yea i will still ne to massage the fire wall for clearance as the rocker cover will most probably rub and where should i run the turbo lines ,if not around the back of the head ?
Posted on: 2010/6/9 9:23
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From mandurah
oh and CA_1200_project i am going to run the skyline tank and run my silvia pump in the R31 pump holder
and the cas cover i made out of an old cover but i just cut the corner of but i left the main mounts there to hold the cas properly
i reckon the cover turned out pretty good .considering it only took about half an hour to make
Posted on: 2010/6/9 9:27
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
Will the s13 pump fit strait into the same tank??? Thats a bonus!
Yer mate you have done a great job or the casing. Looks great. I have looked into after market ones in stainles and they are dear. Anyways loving this thread.
Posted on: 2010/6/9 10:08
From mandurah
im only 16 so funds arent huge so i try to do most the stuff myself
and you can use the holder of the pump from the skyline tank and then just put the pump motor out of a silvia into the sender/motor holder that bolts into the tank ,cos the silvia pump/sender wont bolt in cos its too long
Posted on: 2010/6/9 10:18
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
Funds will hold you back no matter what age you are lol. I keep myself broke with a full time job...:)
And have you found that the silvia pump will pump alot more fuel? If so i might look at going that way as well.
Posted on: 2010/6/9 10:44
From mandurah
umm i havent run it yet but i might this weekend and the skyline pump should work as its for a 3L motor but then the CA is turboed ,and my parts guy said that the silvia pumps are preffered as it is the factory componant and will supply a standard CA with heaps of fuel ,but soon im goin to get a bosch pump to go into the skyline tank and then i just need to bolt in all in yeeooww
Posted on: 2010/6/9 12:12
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
Well for a 16yo you you know what your talking about or are getting good info from someone. Thanks mate i may be doing the same thing to mine now. More $$$ lol. good luck with your drift car
Posted on: 2010/6/10 9:24
