48mm DCOE single weber on A14 ?
From mandurah
would a 48mm weber be too big for a mildly worked A14 and how much more power would this have over a 32/36 weber ? is it worth the trouble and can i buy a manifold to suit it ?
Posted on: 2010/6/10 5:42
Re: 48mm DCOE single weber on A14 ?
yes, too big.
remember, a single DCOE on a plenum manifold flows 98% of what twin DCOEs do with individual throttle bores.
44s would be plenty big. 40s are more commonly used for hot street A14s.
Posted on: 2010/6/10 6:05
From MOOROODUC. Victoria
Twin 42's
jpg  Twin 42s.jpg (22.80 KB)
8710_4c107bf2c7b98.jpg 400X300 px
Posted on: 2010/6/10 6:45
From Sydney, Australia
My bro had twin 48s on his 2.4 stroked L20B in the late 80s.
So it isn't unreasonable, but you'd be the only person on earth doing it.
Posted on: 2010/6/10 9:37
From NZ
Racers run Mini engines on single 48s so not unheard of to run a small 4 on such a set-up. But I'd suggest low down tractability would be rubbish for a street car.
Posted on: 2010/6/10 12:37
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
From mandurah
ok o it will work but will be a little big aand im guessing that the fuel econpmy would be gone haha
would a single weber manifold work or will i ned to make a new one ?
Posted on: 2010/6/10 13:58
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
I had twin 45s on an A12 (actually that's the engine in my avatar pic).... you can do it.
Ask Mike about the A10 in Jaypan running the twin 40's. Just choke the bugger down and go.
Posted on: 2010/6/10 14:29
