« 1 (2)
A series Autos trannys - how tough?
From Invercargill, New Zealand
I'm about to go on a family holiday overseas. Our vehicle for the 3 weeks is an auto B310 A12 which I purchased for extra street cred. Can I treat the auto trans like an A series motor i.e. lots of revs, roll backs etc with no trouble? Will it be a weak point? Should I just grow up and stop showing off to my kids?
Posted on: 2003/12/4 6:21
Re: A series Autos trannys - how tough?
awd magnas have been out since september... raliart coming out in june 2004.... aparently with over 200kw
Posted on: 2003/12/4 10:08
From Adelaide
theres a suzuki sierra? (wierd small convertible 4 wheel drive) that is running a suzuki swift gti engine with a custom turbo setup, I saw it boosting near my house, and we talked for a bit, he spent nearly 25 grand on mods and it still wasnt finished. It went pretty hard but.
Posted on: 2003/12/4 13:04
From Newscastle, Australia
Teretonga...i reckon I may handle the roll backs and youre not showing off to the kids...you are just naturally excessive- compulsive!!!
My big worry for you, in regards to weak points, is the amount of times you will have a spin with too much power-on oversteer (wakefield).
Posted on: 2003/12/5 2:59
Re: A series Autos trannys?
From Brisbane Australia
To the best of my knowledge,Borg warner boxes were used in Oz because of our local content laws and also 1200's were built here.
My Dad used to sell 1200's new and he recalls that the coupe was fully imported from Japan and if you wanted the five speed option you had to wait for the car to be built.
hope my two bobs worth helps
Posted on: 2003/12/5 5:41
From nsw,AUSTRALIA
hey if your using a auto in a 4wd wouldnt that run away like down hills a bit i no of one solution change the torque converter
Posted on: 2003/12/5 7:03
A14+1200 ute=dirty pants
Bump
Digging up this thread again....
anyone know whether the a-series Jatco bellhousing fits the r31 4 speed?
Are r31 4 speeds electronic for the overdrive unit? I had a carbed liteace with a 4 speed overdrive box and it felt like it had infinite ratios....I could go as fast in reverse as forward which was scary fun.
Posted on: 2005/7/12 7:27
« 1 (2)
