« 1 2 (3)
Re: what valve sizes?
From Freo
A14force.. and yuou have the drilling mod for the oil gallery..:)
Posted on: 2010/11/5 11:46
A15 PSI Project Motor
'72 CB750k,
From Christchurch NZ
Actually, this is an H89 head. So that may have been factory?
I've never really played with any of the early heads, (Except for my GX head, which had already been modified before I got it) so I'm not as familair with said mod as I should be.
Posted on: 2010/11/5 21:06
Forced Induction!
From Freo
there is a small hole drilled on an angle, so this late model head can go on an early block, so the oil can come out of the block, into the head stud hole..
Posted on: 2010/11/5 23:55
'72 CB750k,
chances are this was done by whoever fitted the larger valves. When I got it it had done much work. Two of the valve seats were cracked.
Posted on: 2010/11/6 9:14
Forced Induction!
From Forsby Finland
This is 42mm intake and 33mm exhaust valves in a bored 78mm A14, it´s close but it works!
Posted on: 2010/11/7 20:45
I am building a mean Datsun E10 racer , a15 turbocharged engine, aiming for 280hp....
From Tasmania
Dastun100aturbo I need more info about your car and what you have done/ are doing to it.
Posted on: 2010/11/7 22:41
Proud member of " The Tasmanian Datsun Owners Group"
D1000
what are you exhaust valves 33mm?
Id like 38mm in with 35 exhaust for boost.
Marcus
Why is that head another victim of your surgery? :))
If I had my time again Id be a boiler maker tig welder
by trade and weld up material on that head to get the
valves parallel to the pistons and the ports will then
be very highly angled due to this.
Posted on: 2010/11/8 1:14
From Forsby Finland
This was just a test I did in my garage last night to help you guys with the valvesizes! The head is from the same engine that was cut into pieces, I have used it for machining valve cutout in the pistons. I am using 38/33 valves in my turbo engine but I also hava two N/A projectengines in my garage with different setups. (my garage is stuffed with A-engine parts)
Marcus
D wrote:
D1000
Marcus
Posted on: 2010/11/8 7:33
From Forsby Finland
What parts of my project are you interested in? I have done mods to every part of the car and I am never satisfied so the project goes on!
Posted on: 2010/11/8 8:01
From Tasmania
I will PM you and talk about your car there dont want to distrupt this theard.
Posted on: 2010/11/8 21:18
« 1 2 (3)
