« 1 ... 26 27 28 (29) 30 31 32 ... 42 »
Re: Project Drift coupe (AKA 1200 coupe )
From Secret Harbour WA
thats looking good jesse you guys did some good work on the weekend...
and how sweet is it??? now it is drivable !!!!
i'm looking 4ward to working on it now...
keep up the good work jesse
Posted on: 2011/1/24 10:50
From mandurah
cheers man ,i have spent every night for the last month working on stuff to get it running and its starting to pay off ,just need to do fiddly bits in the engine bay and panel work
still heaps of work to do, but im super happy that i can drive it now ,still havent done any skids though haha
and thanks for putting those pics up brett ,nigel your hair is silver blonde not grey hahahaahah
Posted on: 2011/1/24 13:21
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From perth airport
sounds like a powerfull ca18 :P
Posted on: 2011/1/24 22:21
perth airport parking
Datsun 1200 ute A14
From mandurah
haha jordy ,after talking to u on the phone my computer crapped its pants !
i tryed starting it cos i needed to put water in it (after fixing a small leak) and the fuel pumpdidnt work so i tested for power at the pump ,earth but no power, so i then checked at the relay for the negative trigger fromt the computer ,and found out that there was nuthin
so i checked the harness plug ,still nothing ,so i swapped computers and she started straight away
wonder why it died though ,everything is run through relays
Posted on: 2011/1/26 10:23
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Mandurah, Western Australia
Sounds good Jesse, as you said today get stuck into sanding the beast back for paint and touch up the last bits of panel work and will see you at MAX 2011
Posted on: 2011/1/26 11:29
looks good, and nige- your hair isnt grey,its white!
that welder is doing magic for a gasless. i really need to get cracking with mine.
That coupe looks not too bad for a dodge job. keep it up. im seeing a rattle can spray job in its future
Posted on: 2011/1/27 11:03
From Perth WA AUS
Mik, just cause we're in Perth doesn't mean we dont do things properly.
I have selected a nice Dulux exterior paint from Bunnings that can be tinted to almost any colour, just need to buy a decent roller to apply the paint!
Posted on: 2011/1/27 12:56
Datsun 1200 2Dr sedan.
From mandurah
hells no mik ,no way is this thing getting a drift spec spray job
and nigel you might be onto something ! we could wall paper it ! or use rollers ,either way hahaha (no way are we doing either !)
ok so yesterday carps came around and welded the radiator mounts nto the support and i fitted up the dahs without the pad on it
so today i bought a nice peice of ally plate to make a panel for the gauges ,it is the full length of the dash and it will be riveted on ,and im going run the relay harness through the dash and then mount the relays on the face of it so i can easily get to them ,then mount my ignition ,fuel pump and start switches on the dash too ,with either missile covers or just leave then as chrome switches
as for gauges im just going to stick with a tacho (nice and big with a shift light) and oil pressure ,water temp ,and volts aswell
and i started mounting my new boost gauge on the piller awith a hose clamp screwed into the column ,and it just clamps the chrome cover on the back of the gauge
ok so my plan is to ge this thing done or at least fairly pressentable to take it to the MAX car show
that is my new year resolution !
ok so im going to put in a good days work on saturday with
mounting the seat
doing the dash stuff (apart from gauges)
stripping sound deadener off the inner gaurds and little bits on the floor pan inside
roll passenger side rear gaurd
bog some stuff and sand the passenger side rear quarter some more , im not entirely happy with it yet
thats about it ,im an my own the whole weekend so i can do what i want
next im gtoing to try and find a good set of 2 tierods then get them machined to suit the s13 ends ,which im going to get tomorrow (dads first bit of sponsership hahaha)
oh and i did a skid tonight too ,on the concrete out the front ,i rolled back abit then fed it too it haha was pretty good ,didnt struggle too much
Posted on: 2011/1/27 13:36
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From mandurah
oh and there seems to be a rather large water leak which im pretty damn sure is coming from the water pump
i changed the turbo feed pipe tonight so thats stopped leaking
but the real problem is ,when the motor doesnt have any water in it ,it runs like a dream (i only backed it out of the shed and filled the water up) then as soon as it is almost full of water (when the water temp sensor gets surrounded by water) it starts to spit a little out the exhaust ,so my question is ,could it be timing ?? cos the computer would be ruinning warm up enrichment when the sensor is dry ,which alongs more fuel and ive heard less timing
SO if the timing is out then it might advance a little when the water temp sensor gets hot and lets the computer know the motor is warm
if not that then im going to pull the plugs out and pressure test it and check the oil for water ,if it has done a head gasket ill put head studs in it and a steel gasket !
if its not the head gasket then it could also be the manifolds leaking water into the inlet !
which means ill have to pull the inlet maifolds off and put new gaskets on them ,put it all back on and hope if stops !
plug test is going to be my first check though
im getting abit dishearted about this CA
Posted on: 2011/1/27 13:45
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Albany, Perth Australia
hahaha...time for a black top sr20 me thinks hehehe
Posted on: 2011/1/27 14:09
1200 Smerf Mobile
