Question about springs and retainers
Im looking at using smaller springs and retainers
for this particular head so I can angle and enlarge
the ports further. Im looking at 3-5mm less overall.
Can anyone advise if this is possible using smaller
diamter dble or triples valve springs?
jpg  ca18 sohc 8v.JPG (27.23 KB)
737_4d6ecba643f0e.jpg 464X214 px
Posted on: 2011/3/2 22:54
Edited by D on 2011/3/3 4:09:23
Edited by D on 2011/3/3 5:02:53
Re: Question about springs and retainers
bump
anything spring to mind?
Posted on: 2011/3/3 5:31
Quite a regular
From Bellville, RSA
Doesn't look as if anyone is springing into action here...
Posted on: 2011/3/3 14:00
Datsun 1200 Sedan
From mandurah
maybe try finding an off the shelf srping set then get retainers made ?
wouldnt be too deer ,if you got for doubles ,then theres less machine work beened
if you angle the valves wont the springs try to lean aswell ? or is that why your going for small springs ?
good luck !
Posted on: 2011/3/3 15:04
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
yeah trying 2 miss the springs with extra porting, no springs would b best ;0
Posted on: 2011/3/4 0:11
Im going to weld up the spring base area so just wondering
if anyone knows of a small diameter double valve spring
and retainer I could use from another nissan engine?
Im sure the L series ones are just as big wont be any good.
Im going to use larger in/ex valves so need to be steady
enough as well to support bigger valves.
Posted on: 2011/3/8 11:48
