I have been in talks with engineers lately, and because of how homo the NSW government is with modified cars it seems that i am going to get raped by the police if they even see my car on the road.. half the things on the car are un engineerable anyway..
So ive decided to bite the bullet and build the car to compete in ozmod and st289 classes, that means selling my ca setup and getting something competitive.
So up for sale i have the following..
- Good condition CA18DET Long engine, comp tested fine last year (cant remember the figures) but ill do it again soon, block painted black, rocker covers in 2 pack blue with -8An fittings welded on.
- Full cometic ca18 gasket kit, including headgasket
- Brand new ARP headstuds
- Full CA into 1200 wiring modified by the man Kev Rowley himself
- Custom Plenum Creations (CPC) plenum to suit CA into 1200 engine bay, to suit XF throttle body
- Custom steampipe highmount exhaust manifold, T3 flange and provision for external gate (to suit my turbo and gate)
- Good condition used Garrett GT3076R, .63Ar rear housing, no shaft play, impellers in good nick. with speedflow fittings
- Brand new 45mm Turbosmart external wastegate
- Jatco 4 speedautomatic gearbox, billet input and outputs shafts, upgraded clutches and servos, full manual valve body, transbrake, 3200rpm stall, Keas cast deep oil pan, complete unit and crossmember to bolt to CA into 1200.
- Aftermarket billet fuel rail, gold in colour, will modify for twin entry if required
- Maddat engine crossmember and mounts, freshly powdercoated black.
- fuel rail and turbo come with speedflow fittings
- Complete CA into 1200 alloy radiator, stainless piping and silicone hoses
- full 3" stainless side pipe and 2" screamer (will only fit the turbo/wastegate and manifold above ^)
The only things you will need is ECU, fuel system and coils, and a few odds and ends.. great package for someone that doesnt wanna chase parts around for that project.
Would rather sell as a package, if it doesnt sell in a few weeks ill split it up.
After $6000 for the lot, including the gearbox which is worth around $3k
Located near wagga wagga in NSW, willing to help with delivery.
reply here or call/sms 0406143946
Identical to this pic with a slightly different plenum
