What Have People Done to Replace the Interior Door Panels
Quite a regular
From Olympia, WA, USA
Mine are in sad shape (basically falling apart). I've been thinking of using aluminum sheet. I am also considering using 1/4" mahogany plywood (with a clear finish), but I'm not too sure about the 'Woody' look. I ruled out carbon fiber to the the cost. What have people done when they wanted/needed to replace the door panels?
Posted on: 2011/4/7 5:51
"Horsepower... May you always have enough"
Re: What Have People Done to Replace the Interior Door Panels
From Albany, Perth Australia
I just remade new ones and covered it in black vinyl
Posted on: 2011/4/7 6:02
1200 Smerf Mobile
Teflon
vinyl
embossed
padded vinyl
whoa
Posted on: 2011/4/7 6:31
From Geelong
I have aluminium ones, not too bad. Perspex ones the same colour as the car would look sharp I reckon. Or clear perspex :P
Posted on: 2011/4/7 8:25
From Ipswich, QLD
The padded vinyl one is my old ute, anyone seen it around lol, I wanna buy it back!
Anyway, just get foam and vinyl and a backing sheet, its pretty easy to do yourself!
Good luck
Posted on: 2011/4/7 9:12
From Townsville, Qld
I like the padded vinyl one but I'd tweak it a little if it was mine
Posted on: 2011/4/7 9:21
I used my old vinyl door panels as a template and cut out some new panels from a thin MDF sheet, 8mm I think with a jigsaw. Then I used spray glue and wrapped the MDF in some faux fur type fabric that I liked. Added an orange bead to match my paint color scheme. Can't find my photos of them installed at the moment.
jpg  SAM_0648.JPG (107.04 KB)
13419_4d9d7e3a73e04.jpg 500X375 px
Posted on: 2011/4/7 10:05
From Geelong
Yeh i've used 6mm marine ply as it's the same thickness as the original masonite panels. Ya gotta take off a few extra mm on the top and bottom to allow for the panel to slip back into the channels on the door
Posted on: 2011/4/7 12:43
From Townsville, QLD
Ha Ha, the 'whoa' ones are thecrap that was in my coupe.The one behind is my handy work. Used original metal/ply backing piece,spray adhesive on some low density foam, then spray adhesive to black vinyl, stretched over edges and staple gun from behind.
Posted on: 2011/4/7 14:11
Fuel lines this week, turn the key by the weekend.....
