Whipple Twin-Screw Supercharger 1600A
From melbourne
Do you think this Whipple would be over kill on A15 motor ?? Overall Length:420mm
Width:220mm
Height:135mm
Snout length: 140mm
Displacement: 1.6 Liter/Rev
Max continuous RPM: 18,00
Max Peak RPM : 20,00
Max CFM : 1120
Max PSI : 30psi
Peak VE : 99%
Inlet Dimensions : 120 x 35mm
Outlet Dimensions : 140 x 80mm
Posted on: 2011/5/1 9:11
Re: Whipple Twin-Screw Supercharger 1600A
From Coondle, WA Australia
Sprintex Superchargers
These guys have an online blower calculator that might help
Posted on: 2011/5/1 9:24
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
I reckon that's definitely on the too big side.
18,000 & 20,000
Probably more suited to 2 - 3 litre motors, but it kinda comes down to how you set it up and what you want from it.
Pricey that one.
Posted on: 2011/5/1 9:35
From Adelaide
That depends on how much boost you want. Spinning at crank speed it will pump roughly 2.1 times the engine displacement in. The boost pressure will depend on eficiency of the compressor and any intercooling. Intercooling will reduce temp and pressure giving more power for the same pulley ratio. Without intercooling I'd guess at about 18 psi boost. Probably fine with e85. With intercooling it would be closer to maybe 16psi boost and you may get away with PULP fuel with good tuning.
You'd never use it's full range though, you could happily use that charger on a 3-4 L engine.
Take this with a grain of salt as it's a bit of a thumb rule based guess.
Posted on: 2011/5/1 9:45
From Christchurch NZ
It wouldn't be overkill, but it would take a pretty serious engine to take proper advantage of it.
Posted on: 2011/5/1 10:08
Forced Induction!
