« 1 2 3 (4) 5 6 7 8 »
Re: S13 Struts - Firey style!
From Wagga Wagga, NSW
Humm, im not sure if your aware but from my knoledge s13 struts in smaller cars ke70's, coronas, celicas etc and possibly 1200's puts the geometry out of wack, track wise, stub axle angle, strut angle im told it is not the greatest of conversions for smaller older cars
Posted on: 2011/2/11 5:38
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
i thought you might say that
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
From Cape Town, South Africa
TUF, isn't this more or less the same when you install longer LCA, pillow ball mounts, adjustable track rods.
My biggest concern is the steering arms.
Posted on: 2011/2/11 6:33
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
From Townsville, Qld
Yeah I won't give up on this project but things have slowed down with the whole category death cyclone that hit etc. I've been thinking about shocks and struts the whole time and as I will be using these for off road stuff more than tarmac the unit I'll end up with will probly be a Koni 2816 or 2817 inverted monotube as a base. I'd love to trust some cheap coil overs with the task but I gather they're just not meant for people to use them that harshly since they're not long stroke shocks.
These come in a variety of lengths and valving options from koni to suit your McPherson Strut project.
I know there's some sorting out to do with this TUF-110 but the consensus around my motorsport friends is that it's still a viable option. Sure I've thought about just getting R31 struts and doing a coilover conversion on those but unless I am serious about PRC regs (it'd be nice to be a filler in these events show some of them old boys how I pedal) I'd rather try this. Also I'm hungry and need donuts.
I'll get back one of my 910 bluebird arms for playing around with, did you get those over there Racetech? I will start taking more assembly pics with a focus on sussing out the geometry, I really need to refresh my maths skills :P
Posted on: 2011/2/11 7:26
I think we had something like that in RSA, but not that sure, I'm not really worried about LCA, I'll build my own or mod it to fit and work.
I just want adjustable bump and rebound coil overs, if 58mm ID spring fit I'll be thru the roof, but my car will be more a tar rally car, so it needs to be low.
Have a look at my project thread, I'm not scared of work, cutting or modding, as long as my 1200 looks like a 1200 from the outside I'm happy, the inside is a different story all together and my play ground.
Posted on: 2011/2/11 7:36
www.race-tech.co.za
going to have a couple of days off in a few weeks so I'll do some more on this like measuring up the ackerman angle and distance needed for the tierod to avoid bump steer. I think one of those tieods made out of an eyelet joint and spacer would sort it out nicely but would definately get you a no lube session with mr Plod and his aqquaintance mr Dot
Posted on: 2011/5/31 3:37
From mandurah
I have some good news
I found some tie rod end that work on the tie rods and the knuckles
As of yet I havnt found out what they came off but ill get the part number from the box
Posted on: 2011/5/31 5:12
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
cool!
Posted on: 2011/5/31 12:28
From windsor, sydney
ok guys this front strut and brake thread is starting to drag on a bit, there is plenty of info on this site for all wheel sizes and combinations , that said here is a few pics of the s13/s14/r32 front strut/brake setup on my ute , the pics are on multiple replys
jpg  31052011440.jpg (41.21 KB)
9512_4de4dd1ea42c2.jpg 480X640 px
Posted on: 2011/5/31 13:20
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
another
jpg  31052011438.jpg (42.63 KB)
9512_4de4de0c074fc.jpg 480X640 px
Posted on: 2011/5/31 13:24
WARDMAN ENGINEERING
CNC machining
0413 595 627
again
jpg  31052011442.jpg (27.57 KB)
9512_4de4de91119f3.jpg 480X640 px
Posted on: 2011/5/31 13:26
WARDMAN ENGINEERING
CNC machining
0413 595 627
