A couple of videos
From Portland OR. USA
Here are links to a couple of videos taken last weekend at the NWAA practice autocross weekend at Packwood Washington. Saturday started out wet but dried out by lunch. Sunday was dry all day. We reversed the Saturday course with minor changes for Sunday.
Saturday's course was all 3rd gear. The last few runs on Sunday I started using 4th gear for the last left sweeper and final slalom. Using 4th gear for the last part of the run knocked another half second off the run. The course was ~.9 miles long.
Saturday run
Sunday run
Posted on: 2011/6/24 6:22
Re: A couple of videos
From Melbourne AUS
looks like fun!
you deserve a trophy for just remembering the course i say
looks really confusing to me
whats the specs on the datto?
Posted on: 2011/6/24 8:18
1973 B110 A12
From Perth WA AUS
Geeze I was lost after turn 2, nice work!
Posted on: 2011/6/24 12:09
Datsun 1200 2Dr sedan.
From Townsville, Qld
Notice the cones? they dictate what side you're supposed to drive on. It makes a lot of sense.
Posted on: 2011/6/24 12:20
From Perth WA AUS
Yes I figured that out, just got lost in the video :)
Posted on: 2011/6/24 12:45
Still confusing track though, after one cone I gone
jpg  cone god.jpg (74.08 KB)
737_4e047cbc8fe9c.jpg 545X637 px
Posted on: 2011/6/24 13:02
From Cape Town ZA
Watched some of the other vids, I'm sure you can see your car pass by the camera a few times in this video?
http://www.youtube.com/watch?v=HHWakmitbXc
jpg  green datsun.JPG (37.62 KB)
6960_4e05088d7bd9f.jpg 666X408 px
Posted on: 2011/6/24 22:58
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
The course was actually pretty easy to follow. Depth perception in the videos is bad compared to what you see in person.
Car specs:
Mostly stock 1200 engine. Minor porting at manifold/head junction.
Heavily worked front suspension. B310 struts cut down to take Z car cartridges, Ground Control coil over kit with 250# springs. Lengthened lower control arms. Shortened radius rods. Doubled front anti-sway bar. Anti-sway bar ends re-located to line up with control arms. Final alignment is -2.5 degrees camber, +7.1 degrees castor.
Rear suspension has custom adjustable anti-sway bar (made from a front anti-sway bar). 2.5" lowering blocks. The lowering blocks have the shock mounts built in so the rear travel is not limited.
Wheels- Basset racing 13x8 with 4" back space
Tire- Toyo R888 225/45-13
Flares- ZG flares made for Z-car. Front fender opening moved up so top of opening is even with the top of the side body detail line and forward to the bumper pocket. Rear opening raised so the fender opening is even with the bottom of the side body detail line. Front fenders were easy. Rear fenders took over an hour of welding time each to re-join the inner and outer fenders and patch the slits cut into the inner fenders.
I haven't posted any photos of the new wheel/tire/flare combo to the site so here's a few.
Posted on: 2011/6/25 14:28
From Perth WA AUS
Very nice :)
Posted on: 2011/6/26 3:36
