« 1 2 (3) 4 »
Re: Bedtime Story: head CCing
From Adelaide. SA
Hey ddgonzal, Ive got a h75 head which looks like its got great open chambers for turboing... would this be correct? am I going down the right path here?
cheers.
Adam.
Posted on: 2011/7/5 23:37
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
The open chamber heads are not any lesser compression. Not sure if they'd be better for turbo or not.
With factory A-series engines, the compression is controlled mostly by the piston dish.
Posted on: 2011/7/5 23:50
gx1200, use a h89 head or shave your h75 to make it
a close chamber kidney shape & use e15et dished pistons.
Open chamber heads where mainly for poor fuel quality.
Posted on: 2011/7/6 2:44
From Malaysia
mainly for poor fuel quality and for lower NOx emission i guess?
Posted on: 2011/7/6 3:34
From mandurah
My h89 has 24cc chambers
Posted on: 2011/7/6 4:04
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Is your H89 head factory-stock, or has it been ported?
Yes, open chamber is for lower NOx emission. Not anything to do with fuel quality. For lower octane fuel they make the compression ratio a little smaller, like 9:1 instead of 10:1 which calls for high-grade fuel.
Posted on: 2011/7/6 5:09
Interesting that it will get better Nox ratings
I thought closed chamber heads have much better
Nox ratings due to efficiency.
Posted on: 2011/7/6 8:42
From Adelaide
NOx emissions are related to combustion temperatures and the fuel mix.
Posted on: 2011/7/6 9:53
A very poor low Nox design compared to the Z series
pro swirl open chamber dual spark heads :)
Either way the h75 is not a good performance choice unless
its milled for gx1200`s turbo setup.
Posted on: 2011/7/6 14:13
From Christchurch NZ
That was was I had been planning to use for an A14 turbo. Those e15et pistons have a MONSTER dish. My concern was though that having the H75 head shaved that much could create valve to piston issues wheh run in conjunction with a monster cam. (I was planning to zero deck the block as well) Baring in mind that the E15et chamber is something like 18cc. (Thats a lot of meat to shave off an A sereis head)
Posted on: 2011/7/6 21:08
Forced Induction!
« 1 2 (3) 4 »
