60A vs 63A which is best?
From Philadelphia, PA
Between the 60A and 63A which is best behind a high performance A14?
Posted on: 2011/9/13 6:10
Re: 60A vs 63A which is best?
From Invercargill, New Zealand
Both will be fine. Preference for me would be the 63A - stronger gearbox that can handle more torque and you have more ratio options available.
Posted on: 2011/9/13 7:17
I didn't think they made 63 series for a series?
Not a pretty picture but here is the 63 series trans behind one of my A14 motors
jpg  test.jpg (63.29 KB)
490_4e6f0abd323cf.jpg 480X360 px
Posted on: 2011/9/13 8:44
Shh I should have read USA- I never seen one here. Check wiki. I would have thought 63 would be better as bigger
Posted on: 2011/9/13 9:02
From Christchurch NZ
The 63 is a very strong peice of kit.
I abuse mine without mercy. And although the 2nd and third gear synchro's are but a distant memory, I doubt I'll ever be able to break it.
Posted on: 2011/9/13 9:15
Forced Induction!
From south coast nsw
60 would be lighter yeah?.
Posted on: 2011/9/13 10:04
yeah but strength would come into play too greendog. is go for strength if i was hammering it all day.
Posted on: 2011/9/13 10:52
From Portland OR. USA
I prefer the 63A on ratios alone. 1st and 2nd are a little bit taller. This helps close the large gap between 2nd and 3rd that the 60A has. 5th is slightly lower on the 63A also. Makes for a box with nicer gear spacing overall.
The extra strength is nice also.
Posted on: 2011/9/13 15:46
