My datsun 1200 ute wont run
hi guys
Just needing some help i was driving it the other day when it started to cough and cut out when i started it back up i had my foot flat to the floor and the motor wouldnt rev. It now starts and runs for 5 seconds but very rough. i have check ignition spark carby. I havent had the car for long so not to sure on what it is can some one help me out??
cheers
Posted on: 2011/10/4 9:25
Re: My datsun 1200 ute wont run
From RAdelaide
These things can go on for ever basics to check are fuel air and spark. The more you rule out is easier it'll get. I'd check next
Fuel in tank?
Fuel filter clogged?
Posted on: 2011/10/4 9:59
"My mind is a raging torrent, flooded with rivulets of thought, cascading into a waterfall of creative alternatives." - Hedley Lamarr, Blazing Saddles
ild say the coil is rooted go buy a new coil,point,rotor cap,dizzy cap cost about 60 bucks for the lot then you know all thats good and if it doesnt work could only be fuel pump, fuel filter
Posted on: 2011/10/4 11:17
datsun a15 ute
From Perth WA AUS
When you say "It now starts and runs for 5 seconds but very rough"
Do you mean it idles for about 5 seconds or are you trying to rev it aswell?
Just thinking it might be the anti dieselling solonoid.
Posted on: 2011/10/4 11:48
Datsun 1200 2Dr sedan.
From vic
if it was the anti-dieselling solenoid it wouldn't idle but would still rev!
Posted on: 2011/10/4 11:59
From Albany, Perth Australia
was it running fine before? or is it the first time starting, could be timing is out
Posted on: 2011/10/4 13:42
1200 Smerf Mobile
From mandurah
sounds like something to do with the pionts or coil ,it cost me $19 for a set of pionts ,rotor button ,cap .and condensor
mine used to play up around 2 to 3 thousand rpm and it turned out to be the pionts
check the cheap stuff first ,and the antideiseling valve ,it could be jamming half way in the little hole
Posted on: 2011/10/5 5:29
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Perth WA AUS
Sorry mate didnt read your post correctly, gotta be a fuel or spark related issue.
Posted on: 2011/10/5 8:38
I have put and new coil, points and plugs. I have swapped carbys and still no change. Still runs for 5 seconds idealing then cuts out revving the car won't do anything?
Posted on: 2011/10/10 5:08
From ACT Aus
check if your fuel filter is clogged and if you're getting enough pressure
Posted on: 2011/10/10 6:22
unfamilia wrote:
You have bump stops? Your soft
