« 1 2 3 4 (5) 6 7 8 »
Re: S13 brakes onto b110 struts. booyah
Can 14" wheels be used with this conversion?
Posted on: 2011/11/2 15:23
With 250mm rotors some 13's fit even
Posted on: 2011/11/2 18:58
Oh ok. But 14" definetly fit?
I have '84 TRX Bluebird ( Bluebird 910?) shortened struts in my 1200 coupe with Camira inserts and Matching bluebird disc brakes and calipers. It has a 120y booster. Can I still keep this booster with this setup?
I'm planning on completely restoring my coupe from the ground up. Converting my A15 to injection and turbocharging.
I want to completely overhaul the suspension. Everyone seems to be in favour of this conversion.
I'm planning on having it as a street car with the occasional track day. What do you think about this conversion together with a coilover and fully adjustable setup?
What in your opinions has proved to be the best setup/combination overall?
Posted on: 2011/11/2 22:28
From Christchurch NZ
If you already have 910 struts, you can fairly easily adapt rx7 four pots with 280mm discs to them. Although I don't think 14" wheels will clear them though.
Posted on: 2011/11/3 6:43
Forced Induction!
Yeah I don't think I really need to go that big though.
I've decided to keep my worked A15 and turbo that so I'd like to keep with the "light" theme.
If I were going a bigger engine like a CA or SR then I would have considered this.
I don't really think I need bigger than 14" wheels either.
I'd like to get the best performance out of the smallest and lightest brake/strut combo. Having stopping power I'm never going to use or need is pointless and not practical.
Posted on: 2011/11/3 7:35
From Adelaide
Hi Cheater 5,
I know this is an old thread, you said the adapter plates were 12mm and that you had to space the caliper back toward the struts for the drum hubs you used; was 5mm you needed to space the caliper to center it?
If I understand right that means for drum hubs you'd want an adapter plate that's 17mm thick. I'd guess that aluminium may do the job at that thickness.
Cheers
Posted on: 2013/1/8 22:55
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Sydney
Here are some pics of the conversion when I did my brakes. I used 12mm steel brackets.
S13 brake conversion on 120Y struts.
Posted on: 2013/1/9 0:10
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Sydney
lamb_daiquiri wrote:
Hi Cheater 5,
Cheers
I did the conversion on a set of drum hubs a couple of years ago, I sacrificed the original drums to turn them into spacers that locate back on the hub in order to correct the misallignment. it worked out perfect as the drums were designed to fit on those particular hubs.
Posted on: 2013/1/9 0:15
1970 KB10 Coupe
S13 caliper b...
From Adelaide
Thanks
Posted on: 2013/1/9 1:18
From Lisbon
hI!
I want just do the same upgrade brake disc equal yours, let me know if ou use these:
http://i88.photobucket.com/albums/k16 ... olid%20rotor/100_4314.jpg
http://www.nissanpartsdeal.com/parts/ ... e-frt-rh~41001-05a90.html
if dont use nothing like that, please let me know
My actual new wheels 6.0 x 13 Minilite Mag Style / Bolt - On 4x114.3 ET +12
Many thanks on Advance
Luis
Posted on: 2016/4/23 21:54
