Browsing this Thread:
1 Anonymous Users
Re: Flywheel bolts failure\fix\questions |
From Sydney, NSW
happened to me too, the bolts had been over tightened and snapped every single one just outside my house, lucky i had my old a12 to pull them out, but was a bitch to get the snapped bolts out of my crankshaft seeing as the snapped off flush with it, went through a whole set of easy-outs, using the smallest first until it ended up me and my mate with a hammer slamming the reverse screw into it :D re-tightened to 88nm but didnt use loctite, do think loctite is extremely necessary?
Posted on: 2012/1/8 1:08
Snapped crank and still smiling, How do I do it? LOL
From Christchurch NZ
I doubt it was overtightening that snapped them. Probably more the force of the f/wheel hsaking itself loose. Last time it happened to me, (At drags, on my 1st pass too!) some had come undone, and a few had broken off. By the grace of the datsun gods the same forces that broken them, also unbonded the locktite they were glued in with. I was dreading trying to drill out 12.9 tensile stregnth capscrews while groveling on the driveway under the car.
Posted on: 2012/1/8 1:19
Forced Induction! Because everyone knows you don't bring a knife to a gunfight!
From mandurah
The same thing happened to Me
I put new nissan Flywheel bolts in my a15 with a lightened a12 Flywheel and after about 2 months ,probably 4000kms I gave it a real belting and they all snapped apart from 1
So I then put ARP bolts in it and after 200 odd meters they came loose! When i pulled it apart I found they were too long and were bottoming out just before tightening up on the face of the Flywheel ,so I trimmed them up and put loctite in them again and its been all good since
Posted on: 2012/1/8 1:37
77 1200 ute 77mm bore a15 ,12:1 comp ported and reconed h89 head fairly aggro cam ,billet rocker spacers twin 40mm solex carbs on bpro manifold MSD 6al2 with 2 step limiter 4speed 60a box hd clutch 2 inch exhaust locked 4:11 ute diff ...
That's good to know (about the arp ones bottoming out) !!
Another thing that can play a part in high revving 4s is the lack of damper on the front pulley. I don't know if there's anything available off the shelf, or easily adaptable, but it is certainly part of the puzzle with regard to crank bolts coming loose or snapping altogether (of course the most important thing here is proper torque-ing of the bolts, not too little not too much) On a related note, most bolts have only so many tensile cycles they can go through (can only be tensioned and undone and re-used a certain number of times before they lose some of their tensile strength,).. And on that note I'd strongly suggest new bolts for any performance engine buildup. Similar thing for rod bolts. They aren't dirt cheap but are a lot cheaper than a whole new engine (or losing part of your foot, though I must confess i don't know of anyone that has happened to).
Posted on: 2012/1/8 2:20
John McKenzie
Registered Users Contentmaster Usermaster
ARP does not make flywheel bolts for the A-series. So the ones used were intended for a different engine.
Posted on: 2012/1/8 2:45
From Freo
the ones Jesse got were obviosly for something else, but machines shorter and supplied for an A15, but as he is using an A12 lightened Flywheel they bottomed out, all good now..
Japlish translation:
"Indirectly it influences the sudden clutch meat and at the time of high revolution the vibration of the crankshaft which occurs as the flywheel vibration. As a result it is to withstand volt/bolt the vibration and not to be cut off and to develop in looseness and to reach to very dangerous state. This flywheel volt/bolt with the strengthening volt/bolt by the ARP corporation (USA) whose reliability is high with the tightening torque of genuine ratio approximately 1.5 times the looseness of volt/bolt holds down and is packed, to the running which is stabilized leads.
Tightening torque ・・・13.5kg/m (standard 8.0 - 9.0kg/m) * The front [deisubitaipu] A12 crank is not attached because screw pitch differs."
Posted on: 2012/1/8 2:56
'68 Thou Wagon,(home now) up and running '69 2 door project, the yellow thing, A12A Project motor, for the yellow thing. A15 PSI Project Motor '72 CB750k,
From Sydney, NSW
what kind of High Tensile bolts did you use for your flywheel? i would rather remove the stock ones and put some nice new ones in because my a15 makes 140hp and i just want to remove the problems, cheers
Dion
Posted on: 2012/1/8 4:12
guys report no problems with brand new nissan high-strength bolts. Dowl the crankshaft, torque them properly and go racing.
Posted on: 2012/1/8 4:38
Quite a regular
Quote: went through a whole set of easy-outs, Left-Hand drill bits often remove broken bolts as well and sometimes easier than easy-outs Ease-Outs exert an outward force against the thread holes whereas LH bits do not. Quote: is the use of Loctite necessary Not in my view, in "This" application as the vibration is minimal, Granted do make Note the usage you guys are putting the A series is beyond by experience. Regarding "Proper" bolt torque, this is related to several usages. 1 - Clamping Force 2 - Bearing "Crush" Force Regarding the Pressure plate & Flywheel use, I suggest going by the bolt capacity chart instead of the Nissan suggested torque. http://www.dansmc.com/torque_chart.htmRusty Wrench
Posted on: 2012/1/8 6:05
From Sydney, NSW
where abouts do i get these nissan high tensile bolts? could really use them.
and yeah i had to drill with the left hand drill bit, then hammer them easy out into the hole, 4 of them came out using the left hand drill bit but the other 2 required hammering the easy out into the drilled hole,
NOTE: took me and my mate 2 hours to get them all out, high tensile bolts are a real bitch....
Posted on: 2012/1/8 6:31
