« 1 (2)
Re: vibration
From Adelaide
Wheels are usually close to 50-60kmh, drive shaft higher. Old holden drive shafts will vibrate at about 95kmh if they're out. The solution is to get it rebalanced or get another one.
Posted on: 2012/1/20 7:02
Re: vibration
From Ballarat Victoria
Try running it up to speed on jack stands with the wheels off. be sure to put wheel nuts on the studs to prevent the drums/discs from moving.
If the vibration is still there, you know its the tailshaft.
Posted on: 2012/1/20 7:22
VIC DYNO HIRE
Re: vibration
From Sydney, NSW
yeah my one does it too, certain rpm 4th gear between 60 - 80, kind of annoying but i try to ignore it.
Posted on: 2012/1/20 15:33
Snapped crank and still smiling, How do I do it? LOL
Re: vibration
From Gold Coast, QLD, Australia
yep all definately firing
will try some of the things suggested
thanks
Posted on: 2012/1/23 1:24
Re: vibration
Quite a regular
Out-of-round tires or rims.
I suspect some side to side wobble as well as O-R diameter.
0.125" max wheel O.R. was a number I recall, don't bet on that one though, I'm not sure. Can't recall the side to side figure at all.
Had the same exact issue with my 75 V-8 4-sp Monza, I HAD to go over the US Wide 55mph to run smooth..
A Bud had a tire "Trueing" machine, trued up the tires, No Vibration anywhere.
Drive-shaft, {Ute}? ARE WE still Talking 1200's Here ?
If so, U-Joint 'phasing' isn't as big a deal as the independent rear suspension cars unless jacked up. Still I feel the tires/wheels are the issue.
Why, cause it goes away at more speed, the "Out of Balance" drive-shafts got worse with speed.
Still make sure they're "opposed" U-know, one flops up and the other to the side?
On the 510 and the like, the rear Half-Shafts must be opposed or the car will jump up and down at walking speeds.
Posted on: 2012/1/24 5:01
Re: vibration
From New Zealand
have you had a wheel alignment done recently?? mine had a bad vibration at 40mph (60ish kph) and was fixed instantly with a wheel alignment
Posted on: 2012/1/24 5:10
« 1 (2)
