Re: throttle cable end?
basically need to mod a longer throllte cable
Where did you get the longer throttle cable?
B210 seems to have a marginally longer cable than B110, but it's nearly the same. B310 cable has totally different firewall end.
Posted on: 2012/6/15 18:25
Not any snubbed Nige but you have limited stash so save them.
Cable needs to be 1m to 1.10 long dd so its off a cortina or I have a corolla gear shifter cable I could use too
Posted on: 2012/6/16 1:00
From Freo
the solder and Brass ends Barrel or ball, is very comon, motorbike places do it all the time,
don't be shy givving it a crack.. tiz very reliable..
Cable ideas
Posted on: 2012/6/16 4:25
A15 PSI Project Motor
'72 CB750k,
From windsor, sydney
dont use normal tin solder , go for silver solder, not the crappy plumbers stuff but the 10/15% good stuff and use the proper flux , i have made plenty of throttle ,clutch and hand brake cables in the past and not had a come back
Posted on: 2012/6/16 8:43
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
Where to get silver solder and flux? Bindings crap won't cut it I guess
Posted on: 2012/6/16 10:23
BOC or welding supply place should have it
Posted on: 2012/6/17 5:20
WARDMAN ENGINEERING
CNC machining
0413 595 627
From Perth WA AUS
Mik I dont need them and have two that you can have. :)
Posted on: 2012/6/17 11:53
Datsun 1200 2Dr sedan.
From mandurah
mik! go to a gokart shop ,i got the end that hold the cable for a couple of dollars ,and the cable with outer cable for $5 ,and it was 1700mm long so its plenty long
theres 2 types ,one has the ball and the other has the round datsun stock style thing ,all you do it buy the cable joiner they sell and run the cable through then use the joiner to do what the ball would normaly do ,then adjust it with the grub screw
did it with my ca when it was in my corolla ,easy as and all cable bits can be bought from go kart shops ,youdbe suprised what they have!
Posted on: 2012/6/17 13:17
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Yeah need to find go Kart shop round here. But the thought of Nige's nuts in my hands was appealing for about 1sec
Posted on: 2012/6/17 13:48
From Geelong, Vic
man you make things complicated. just get a normal end and have it brazed on
Posted on: 2012/6/18 3:52
« 1 (2) 3 »
