Unleaded
From Stellenbosch South Africa
Can my '73 GX coupe use unleaded fuel?
Posted on: 2004/3/31 16:28
Re: Unleaded
From Bushy, Bush
Posted on: 2004/3/31 16:36
Re: Unleaded
From Melbourne, Australia
i believe anything with an alloy head has hardened valve seats and can use unleaded, which is all a-series motors
Posted on: 2004/3/31 17:11
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Unleaded
From Perth W.A
from what i have been told japan never used leaded fuel or at least havn't used it in the time that they have exported cars so they are all unleaded, don't qoute me it's just what i have been told.
Posted on: 2004/4/1 3:07
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Re: Unleaded
From WA
bingo.
all datsun engines, bar the J series engines and previous (J13 and J15 are seen the the P310, P410 and 1500 utes) can run on ULP with no probs at all, except be nice to the world you live in and fit a catalytic convertor if you do.
Posted on: 2004/4/1 3:36
Re: Unleaded
From South Africa, Bloemfontein
In South Africa we have a Datsun/Nissan Factory.
Did we get the engines from Japan and just assebled them meaning I can also use unleaded due to it being manufactured in Japan?
We are going to only unleaded in 2006.
We can still use for now leaded.
Posted on: 2004/4/1 7:45
Re: Unleaded
It doesn't matter where the engine was assembled. Alloy heads have seat inserts, as opposed to cast iron heads with integral seats. The inserts apparently are hardened. Cast iron heads may or may not have the seat area "treated".
In any case, we've been using unleaded in the US for about 15 years, and no problems even with cast iron heads (the fuel companies put additives in the fuel that work with any kind of valve seat).
Posted on: 2004/4/1 8:00
Re: Unleaded
From durban, south africa
the thing is in S.A our fuel is a crap quality, it has a high sulphur content and at altitude the fuel there has more alcohol in it to give those cars a extra boost.
we've been told to use 4 tanks unleaded to 1 tank leaded.
Posted on: 2004/4/1 9:41
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: Unleaded
Nick, you have raised a couple of important points.
(1) All IC fuels should have some sulphur (sulfur for Dave Gonzales) in them. If there is too much, you are wasting a prime feedstock for the manufacture of sulphuric acid (sulfuric for Dave etc.) If your fuel is crap, I don't know why as there is ample knowhow to make a halfway decent ULP.
(2) Small quantities of methanol in motor fuel are not a bad thing, we just seem to chuck a hissy fit whenever CH3OH is mentioned.
Talk to me about C2H5OH and it gets interesting.
Posted on: 2004/4/1 12:24
Re: Unleaded
Ok what is CH30H and C2H50H????
Posted on: 2004/4/1 13:15
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
