ute weight in standard form
From Goulburn NSW
Hi guys i know this has been discussed before but whats the exact height off a ute.
Posted on: 2012/6/27 7:32
Re: ute weight in standard form
Height: 1395 mm
That's the nominal/official height with the stock 12" tires.
Posted on: 2012/6/27 7:53
From Goulburn NSW
Ah #OOPS# i ment weight.
Posted on: 2012/6/27 7:54
Ange had his weighed pre-conversion. It was 730kg.
Ute: 730kg (one example measured)
Coupe is 750kg (manual)
Sedans are 696-741 kg
It all depends on how much fuel, and if using stock components. Plus options like carpet, tranmission type, etc.
Posted on: 2012/6/27 8:05
From MOOROODUC. Victoria
If 730Kg for a ute is the official original kerb side weight then at the regulations (times 2.5) a CA18DET at 1809cc would just fit into the guidelines.
How official is 730Kg's ?? - what does the roads authority say ?
Posted on: 2012/6/27 8:53
with utes in WA i am sure the regs are the heaviest vehicle of that model... being the coupe... so ca18det scrapes in
Posted on: 2012/6/27 9:03
It's not official at all. It's what Ange measured for his ute.
The "official" measurement that the state cares about is usually either the published tare weight or the Engineer's measurement.
Posted on: 2012/6/27 9:05
From south coast nsw
me nsw rego paper say 720 im 99% sure
edit:no i was wrong rego paper says tare 690kg gvm 1380.. 85 ute
Posted on: 2012/6/27 9:06
Edited by greendog on 2012/6/27 10:03:58
From Canberra
On my rego papers it has the tare weight at 690kg. When I did my conversion the ACT rego people said that they take the weight of the heaviest model in the range which is the wagon at 720kg (720 x 2.5 = 1800). just ring the rta, it'll save a heap of rumors.
Posted on: 2012/6/27 9:07
YLD.18L
From Goulburn NSW
My rego papers say tare weight is 680kg.
Posted on: 2012/6/27 9:46
