« 1 2 (3) 4 5 6 »
Re: I am a VSCCS Engineer - NSW Registration of Modified/Altered Vehicles
From MOOROODUC. Victoria
oh, don't get me wrong .... I will get it engineered fully before I register it
Posted on: 2012/7/14 11:14
Quite a regular
From Mid North Coast N.S.W
Thanks for the reply mate. A blue slip is do-able, a new engineers report for this car is un-do-able.
Thanks again.
Posted on: 2012/7/14 12:32
'72' B110 sdn
'68' (allegedly) B110 sdn
'72' 808 sdn
'00' E50 ELGRAND
'93' JZA80 Supra
From Sydney
Good idea demacoz.
Posted on: 2012/7/15 4:07
From Goulburn NSW
Hi 25gtv can u move the chassie rails inward on a ute and get it passed or is it a nono to alter the chassie in anyway or form.
Posted on: 2012/7/16 10:34
From newcastle, NSW
I'm intereseted to know about the legalitities of an A-series turbo?
What you be looking for to fully engineer an A-15 turbo?
Posted on: 2012/7/16 10:49
From Sydney
mcdat, It would be very difficult to move the chassis rails and have it passed as safe. Manufacturers spend a lot of time and wreck a lot of vehicles to be sure that the design is ideal. I would need to see the car and the design plans. What is the goal/reason for moving the rails?
steveo, The legalities of a conversion like this can be simple or complex depending on the year model of your car and what ADRs it needs to comply with. It is definitely passable. Obviously there would need to be upgrades to the brake system etc. Price will vary car to car. Give me a call for more info.
Cheers
Posted on: 2012/7/17 0:59
From mandurah
Hey Matt
Just wondering ,do you see any problems with putting an rb30t into a 92 rodeo ute? It cane our with a 2.6l 4 cylinder petrol and ive put a 3lt turbo 6 in it
As far room goes it fits but I've had to cut the rad support to get the motor and box in as one peice
My question is
Will 10mm thick plate be enough for the engine mounts ,they're plates that bolt to the stock chassis mounts and have grade 8 12mm bolts holding them to the chassis and then the rubber moun lt bolts into them about an inch forward
What's the type with clearancing ? The head is about an inch away from the firewall
And the radiator is about an inch away from the timing cover
The sump is custom and has heaps of room and won't rub on anything
The tunnel is stock hasnt been belted at all ,Shifter hole has moved back about 30mm ,is that a problem?
sorry for bombing a datsun forum with my #OOPS# but not very often you get to ask these type of questions
Cheers
Posted on: 2012/7/17 2:21
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Sydney
Hi estyre,
I don't see any problems with the compliance of this vehicle.
With the clearances and the rad support, I would suggest a 'half way' / 'First inspection' just to see how things are and to make some comments on how further changes should be done.
The tunnel will need to be reinforced but this is nothing serious.
Feel free to give me a call if your ready to go ahead with the process or just need some further info.
Posted on: 2012/7/17 11:18
From SYDNEY,NSW
im at menai and wonder do you guys come out an look at a car before actually bringing the car in for final inspection? rather than transport back and forth to the workshop? not sure if this is how it works for blue slips and engineering
Posted on: 2012/7/18 0:55
vouch points for PIGDOG J-Dat dats-me TRAV 40RST minitruckin 120fly DEMO 1200dat aidaniel matty discobob mick1200 cemax DATSKOOL - all have helped me out with parts...Thankyou
From Sydney
mradtee23, I do come out and do a first inspection on site if it is necessary. However, as this is for the purpose of registration there is a section in the RMS/RTA website that gives you permission to drive unregistered vehicles to a workshop etc. One issue is that if the car is deemed to be unsafe I MUST provide you with a letter stating that the vehicle must not be driven and then you would be stuck at my premises.
If you are ready for a first inspection feel free to give me a call. Usually this is just a look and discussion about what needs to be changed etc.
Regards
Matthew Rog
M.R CORP
0499234218
Posted on: 2012/7/18 1:03
« 1 2 (3) 4 5 6 »
