(1) 2 3 »
CylinderHead Can't Come off.
From Trinidad and tobago
Hey Today i was scraping my a15I baught.
Took of Fuel pump,Oil pump And intake and exhaust manifoild.
When Come to take of the Cylinderhead.Three bolts would not slacken they are all ring up because of trying at it,tryied every thing long and short leverage everything..I need urgent help..Thanks You.
Posted on: 2012/7/21 3:51
Edited by darrenwilson on 2012/7/21 16:32:37
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: CylinderHead Can't Come off.
From Melbourne, Australia
Get a bigger lever!
If when you say "all ring up" that the hex s gone off the bolts then you're in a bit of trouble! You'll need to either die grind off the heads of the bolts or weld something on to them to get them off.
Posted on: 2012/7/21 3:55
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
From south australia
If the bolt hea is stripped. Try get a
Small pipe rench on to it. The more pressure you put on a pipe rench the more it will tighten and grip on the bolt head.
Posted on: 2012/7/21 4:05
From Christchurch NZ
And remember lefty loosy, righty tighty
Posted on: 2012/7/21 4:28
From Perth, West Aussie
try belting a slightly smaller socket onto it, especially if you have already done a good job rounding it :) .. have you tried a little bit of heat with an oxy or a one of those bernzomatic butane burners? tried pouring penetrene on it liberally for a few nights prior to undoing it? also wurth do this spray that has penetrating oil combined with a freezing compound call rost-off which not many people know about but really helps. one of those metre long torsion bars really come in handy for doing jobs like this.
Posted on: 2012/7/21 13:20
From Brisvegas
good #OOPS# that rost off
Posted on: 2012/7/21 13:27
1980 Datsun 1200 ute CA18DET
i know you can get it at toolmart in WA, it's expensive (about $20 a can) but well worth it over WD40 and the like...
Posted on: 2012/7/21 17:03
Thanks Guys I will try to heat up the Bolts a bit then try to slacken them.
Here is a pic.
jpg  Pic0721008.jpg (136.85 KB)
12526_500ae3b488f8b.jpg 986X789 px
jpg  Pic0721007.jpg (85.41 KB)
12526_500ae3d5d511b.jpg 845X676 px
Posted on: 2012/7/21 18:16
Street Sleeper!
From mandurah
Rost off ice if awesome ,works realy well
Couldnt you just grind the head of the bolts off then lift the head? Then undo the bolts ,and maybe soak them with Rost off or wd40
Good luck!
Posted on: 2012/7/21 18:27
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Yeh my little pipe wrench would get them with no problem at all
Posted on: 2012/7/22 1:02
(1) 2 3 »
