« 1 (2) 3 4 »
Re: Brave Motorsport (SA) items
From Tasmania
Is the hand brake lockable??
Posted on: 2012/7/26 0:28
Proud member of " The Tasmanian Datsun Owners Group"
I understand the rule as being
-if your brakes or line have failed in any way you have a emergency/park brake-
So tapping a hydro hand brake into the same line as your brake peddle is making the emergency brake useless. Needs to be routed on a separate system...hence not using the same braking method to the normal brake peddle
My understanding. Would be convenient to have it in the same lines to illuminate the need for cables
Posted on: 2012/7/26 2:47
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
A hydro handbrake doesn't make the existing handbrake useless. They are separate systems, one uses hydraulics, the other is cable operated. Only if you disconnect the standard one does it interfere (which a lot of people do, using the same handle).
Posted on: 2012/7/26 4:11
Who would run two there on the street???
Answer is if you want one handle then NO hydro is not going to pass rwc
Posted on: 2012/7/26 7:55
From hastings,vic
you join the cable to the hydrulic hand brake as well
once it passes you back of the cable hyd will work before
cable and if you get a hole in the line cable still there
to stop you (E BRAKE)
Posted on: 2012/7/26 8:32
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From radelaide
hey if your interseted in any of those mags and anymore that i post up msg this guy and say u were told by me Dave @ BRAVE MOTORSPORT about them
Kane 0406366502 from eye candy auto assessories
many more to come
told ya
jpg  nemoto borb 15x8 +15.jpg (12.55 KB)
14180_5011252b71077.jpg 300X300 px
jpg  nemoto mesh 15x7 +20.jpg (15.40 KB)
14180_5011253821906.jpg 300X300 px
jpg  nemoto rs 15x8 +15.jpg (16.41 KB)
14180_501125591adac.jpg 300X300 px
Posted on: 2012/7/26 12:04
HY_FLO MOTORSPORT - designing a new wave in motorsport
hy.flo912@gmail.com
0411 725 347
www.facebook.com/HyFloMotorsport
FOLLOW ME
From Geelong, Vic
National vehicle safety guidelines state that the emergency brakes must be of mechanical opperation, so no hydraulics....but for some reason you are allowed electric park/emergency brakes which i wouldnt really say are a mechanical means, all the new mercs have push button electric park brakes
so yeah, dont go buying a hydraulic handbrake setup expecting it to pass a roadworthy inspection
more so used for rally and drifting to get the rears to lock up quick and easily
Posted on: 2012/7/27 4:08
From Melbourne, Australia
the electric push button jobs still act mechanically, but i see your point
the hydraulic is the scary one as it can leak over time and come loose
great for handbrake turns and such but pointless for holding car still, most rally cars etc run the two brakes so they retain the original as well
Posted on: 2012/7/27 4:18
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sydney, NSW
Posted on: 2012/7/27 12:36
Snapped crank and still smiling, How do I do it? LOL
From Perth
If you want to get real fancy you use a dual hydraulic handbrake with 2 levers so you can work each rear brake individually
Good for sliding around cones on motokhanas
But no... you can't use them for rego as you need a cable
Hydraulics can leak down and cause the vehicle to run away
Also as the system cools down... things contract and even if you think you have the handbrake on tight... it can still run off when everythings cold
Posted on: 2012/7/27 15:07
« 1 (2) 3 4 »
