A series hot up bits, A15,Wheels +More!
From Ballarat Victoria
$SOLD-Double Valve Springs,SH SOLD
$SOLD-New Double springs with SH ally retainers. SOLD.
$SOLD-EFI manifold Just taken off my turbo engine(no rail, injectors or TB).SOLD
$SOLD-Coil on plug setup, inc neat ally brackets. SOLD
$SOLD- turbo/ blower grind cam(wider lobe separation),SH. SOLD
$SOLD- Electronic IGN and coil(cracked Cap). SOLD
$180- S/H 32/36 Weber on oval port manifold(no choke or air cleaner)has had repairs to manifold and adaptor is welded to manifold.
$600-Full SS manderel bent tig welded extractors and full manderel SS exhaust system to suit A14/15 in ute. Was used with the EFI Manifold listed above.
Other bits:
$350-13x7 Rebels
$750-13x7 Starsharks
$100 each-Water to Air Intercoolers
$700- NOS, T50 gearbox
$150- As new Eibach coilover springs 150LB, Have original boxes that they came in
$150- As new Eibach coilover springs 200LB, Have original boxes that they came in
$80- Coilover springs, unknown brand 175LB
$700-A15 Engine, Big bore, Flat tops, Cam, in good cond.(bottom end only).
All i can think of for now.
Posted on: 2012/8/4 15:55
Edited by sikyne on 2012/8/4 16:18:10
Edited by sikyne on 2012/8/6 15:33:41
Edited by sikyne on 2012/8/23 5:21:51
VIC DYNO HIRE
Re: A series hot up bits, A15,Wheels +More!
From Perth
Interested in #2 and #5 if your willing to post
Posted on: 2012/8/4 16:15
From Sydney
Interested in the headers Simon. Can you please pm me your contact number.
Posted on: 2012/8/4 23:04
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
do you know the offset of the starsharks?
Posted on: 2012/8/5 0:46
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From Townsville
Got some pictures of wheels
Posted on: 2012/8/5 1:10
PM`s replied to. I`ll have to check the Starshark offset, but think they are "0".
I`ll put up some wheel pics.
Im happy to post cam and springs.
Posted on: 2012/8/5 2:51
VIC DYNO HIRE
From Adelaide South Australia
do you have a round port manifold for those carbys because i want a bigger caby on my A12
Posted on: 2012/8/5 5:29
Not too shy to talk
Pics of wheels pls?
Posted on: 2012/8/5 6:08
the electronic ignition - is this a pulsar distributor based setup or something else?
Posted on: 2012/8/5 10:52
John McKenzie
From Adelaide Hills
Could you measure the backspace on the rebels please. Spuwin your in VIC. Got friends coming down from Castlemain in October tho...
Posted on: 2012/8/5 11:38
