« 1 2 (3) 4 »
Re: SHED CLEANOUT ! perth ,must go !
Haha lol good one I like your sense of humor.... So how much does estyre owe u? May aswell square it all up and get it it sorted now
Posted on: 2012/8/7 12:18
From Wanneroo, Western Australia
Estyre I might be interested in some engine bits, what do you have? I only need to pack a swag and drive from one end of the Freeway to the other, so no postage required!
Posted on: 2012/8/7 13:07
Like I said matter of principles only, I let out steam already, carry on as usual.
Posted on: 2012/8/7 13:18
From mandurah
hey jmac nah no castor rods ,as for the lights ,some have different lenses broken and frames ,so as a whole ,the lot of them would be good to build a good set of lights ,thats why i got them ,not sure what theyre worth though ,pm me an offer and i can send you some pics ,if its just lenses your after i could put a complete let of lenses together ,that wouldnt be a problem if its only the lenses you need
D i spoke to the guy that used to own the carbs ,all jets were there and so were the fuel float and other major internalk bits ,if they were missing why didnt you mention it before ,first ive heard of it
also if all off topic posts could be removed ide appreciate it
cheers
Posted on: 2012/8/7 14:42
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From mandurah
as for engine parts ive got
complete a12 needs manifolds dizzy and little fiddly bits
a14 flywheel
l series gx/su carbs ,on manifold running setup ,with air bolx and linkages
stock a12 cam and gear
homemade (not by me) turbo manifold suit all a seris ,with oil line and a shady t25
stromberg carb ,cd175 suit turbo setup (not jetted)
60a bellhousig ad rear housing ,pretty much everything except the gear set
2 stock a series cabs ,12 i think ,one is late model with electric choke and the other is the older style
mostly complete a12 ,runs but has lowish comp on cylinder 3 ,new head gasket ,needs sump gasket ,water pump ,dzzy ,oil pump and has a fiarly lumpy cam in it
a12 heads ,varying condition
1200 ute tailshaft ,needs cleaning as theres some surface rust on the front yoke (or replace it with another on
near new fuel pump ,used for about a week then found out it couldnt supply enough fuel to my heavily worked a15 and was dropping pressure at around 8000rpm ,so i went electric
also got 1200 ute leaf springs with new bushes ,painted red ,u bolts and shocky mounts
also if anyones keen ill take 200 for the coupe and the ute shells ,or 100 each ! with spares for the coupe
Posted on: 2012/8/7 14:53
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Secret Harbour WA
Jesse sorry dude my phone keeps playing up and would let me send you a pm
So anyway I'll be back from Thailand on Saturday
Will give you a call Sunday if cool. And we can work out a day you want to come round my workshop
and have a look at the cars. So your after a ute shell yeah?
have two spare plus two wagons one sedan and one coupe.
Could use the room as I just picked up a 240k hardtop coupe.
Anyway will talk soon.
Bump for Jesse!!!
Posted on: 2012/8/8 5:13
76' B120 GX Style Ute
73' B110 coupe
75' Mini Van
77' Mini Van
71' R100 13B PP i miss it!!! its hiding in my garage in QLD
69' R100 GS Jap Spec
67' Mazda 1500 13b turbo
91' BMW e36 318
From mandurah
yea cheers man ,im keen on a ute, but if i cant get a good shell ide like a wagon
pretty keen to see this 240k youve got too!
cheers
Posted on: 2012/8/8 6:44
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
mate I'll happily give you $200 for the coupe doors (sight unseen) as long as they are complete (I don't mind if the interior trim is stuffed as long as the windows and window mechanisms and lock/handles are all there
Withg regard to the tail-lights - I basically need a complete set, lenses, backing plates - the whole assembly. I've got a coupe shell, but it has no tail-lights whatsoever. If you can make a set out of what is there, I'm happy to buy them. When I say "if you can make a set" I don't actually mean I'm expecting you to have to do that for me. What I mean is - 'if one working pair can be made from the bits and pieces' sort of thing. If that is a possibility, I'm keen to move forward with working out a price that is fair. I'd very much like pictures if possible, of all the lenses, so I can work out what is what, so to speak.
Also count me in for the ute tailshaft would $80 do.
I realise this would all then need to be shipped over. If you can get it to a pack and send near you, I'll get them to pack it all on a pallet and send it here at my costs (I'll have to work out prices with them, but I'm ok with doing that.
So - can you come up with a price for the doors, the tailshaft, and whatever combo of parts it'd take to make a pair of complete tail light assemblies (I'm ok with $200 for the doors, and $80 for the tailshaft, let me know if you want to work something else out) and I'll have to hold on working out a $$ for the tail lights till I see pics.
I'm also happy if you want to negotiate this via PM or email rather than on here:
mail4jmac@gmail.com
If I could ask (and I'm not interested in getting into the 'he said she said' stuff - just curious if maybe I can help) - what parts are missing from the carbs? Ironically floats and throttle plates (and throttle shafts) are actually pretty easy to get/replace, but the 'hard stuff' is generally either the main body itself, or the fuel bowl covers, such that they are, since mostly that stuff is only going to come from another carb that was put aside for parts. Note that i'm not saying that that makes either party better or worse off, but if there _is_ a particular part missing, maybe, just maybe, I can help out, and if I've got it I'll pass it D's way for free, which (I hope) would sort of help both parties out. Heck I might even be able to make the part if absolute worse comes to worse (It won't have a weber name cast on it or anything but I might be able to make a functionally identical replacement!)
ACtually this might be an issue - I just looked at pack n send - are any of the following a reasonable distance for you?
Bibra Lake
Unit 2/9 Parkes Street, COCKBURN CENTRAL, WA 6164
Fremantle
9 Cantonment Street, FREMANTLE, WA 6160
Canning Vale
Unit 3, 25 Yampi Way, Willetton, WA 6155
They all are about 60km. maybe if I threw in a few bucks for fuel as well?
Posted on: 2012/8/8 7:46
John McKenzie
How much are you looking for the a14 flywheel and leaf springs? Also, any oval port heads amongst your collection? If so, what condition are they in? As for the engines themselves, are they early or late A12's?
Cheers,
Alan.
Posted on: 2012/8/8 9:01
Sill keen for the complete A12 (not the one low on compression though :D )
You has my number.
Oh, and +1 for previous dealings with Jesse that I am happy with.
Posted on: 2012/8/9 5:40
« 1 2 (3) 4 »
