ca18det
Quite a regular
From gold coast
is this a good deal?
i want to put a ca18det int my 1200 ute and i found a motor, box, loom and ecu for $2500 just want to know if it is worth it thanks
Nick.
Posted on: 2012/8/7 7:44
Re: ca18det
From penrith,sydney,aus
not unless it rebuilt, if you arent in a rush they pop up for 1000 to 1500 most the time
Posted on: 2012/8/7 8:31
2 door 1200 sedan project l20b stroker
Re: ca18det
From Melbourne, Australia
you probably wont want to use the silvia box either
i would want some compression test results for that price
Posted on: 2012/8/7 8:38
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: ca18det
whats wrong with a silvia box??
i used a ca20 box out of a pintara in my wagon and it ran 20psi all day and lasted almost a year of hard driving, then i put in a silvia ca18det box and was even better handled the power of the ca no worries, if its the length, its not that bad the shifter actually sits in a nice position in my opinion
Posted on: 2012/8/7 8:43
Re: ca18det
In the wagon its different cause you can change gears while in the back :)
Posted on: 2012/8/7 9:40
Re: ca18det
From Ipswich, QLD
That seems like a lot? Aftermarket ecu? The pop up pretty cheap sometimes mate, like around the $1k mark for reasonably decent ones.
Posted on: 2012/8/8 9:17
Re: ca18det
From Goulburn NSW
I payed $700 for complete ca8det and gearbox with only 40,000 km on them.
Posted on: 2012/8/8 9:30
Re: ca18det
Quite a regular
From Mid North Coast N.S.W
For what it's worth...
I bought a CA18DET from Rocco's Performance 12 years ago for $2300 and it came with air flow meter, gearbox, wiring loom, comp and other bits and pieces.
IMO $2500 seems reasonable if the kms are right. A compression test shouldn't be a problem if the bloke has nothing to hide.
Mine was in a Sunny Panel Van. Tuned to 160 RWKW with T28 and Series 5 RX7 front mount, (by Scott @ Insight), it was very decent indeed. And never had a problem with the gearbox.
I also bought an N/A with loom, gearbox and comp for $200 a few months back which now has the turbo stuff bolted to it, but that car hasn't been driven properly yet......
Posted on: 2012/8/8 9:55
'72' B110 sdn
'68' (allegedly) B110 sdn
'72' 808 sdn
'00' E50 ELGRAND
'93' JZA80 Supra
Re: ca18det
I bought a complete ca18det setup for 1100
Posted on: 2012/8/8 10:20
Car free
Re: ca18det
From Canberra
I my opinion unless you can prove that it's healthy then it isn't worth more than a few hundred dollars. Not worth the risk on unproven engines.
Posted on: 2012/8/8 23:36
YLD.18L
