« 1 2 (3) 4 »
Re: suggestions l20b or a15
From Goldcoast
I am thinking about building a A15 and running a super charger. I wonder how much hp a super charger would add to a worked A15 if it was done properly?
Posted on: 2012/8/31 10:58
L16 can later have Z18et top end put in :) crossflow turbo setup
Posted on: 2012/8/31 11:06
From Melbourne, Australia
120y was designed for L-series and has an extra 150kg of strengthening to suit this... I say go for what it was built for!
Posted on: 2012/8/31 12:36
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From stinking hot cairns
L-series would be my pick but I'm bias. it it just so happens this is for sale on ozdat
http://ozdat.com/forum/viewtopic.php?f=55&t=29425
Posted on: 2012/9/1 1:28
Not too shy to talk
From Perth WA
Hi guys cheers for all the suggestions, keep them coming! learning heaps.
Unfamilia: got auto 4 door so diff and driveshaft good? and stanza x member easy to get? Am favouring l20 at this stage. Want the power.
Warner01: Are ca18s alot of work to get in?
Havent made my mind up yet, just trying to get info. Cheers
jpg  DSCF1563r4.jpg (128.94 KB)
11422_5041d337bf800.jpg 400X300 px
Posted on: 2012/9/1 10:20
What year model sedan? Easy to tell if bw or h145, are the diff pumpkin bolts on the gear box side of diff or is the a plate with 8 or so bolts on the back of diff housing facing the boot lid side? Plate at rear is bw and bolts on box side is h145.
Posted on: 2012/9/1 10:44
Not too shy to talk
From Perth WA
have a look tomorrow cheers bro
Posted on: 2012/9/1 11:55
From south australia
I dont know exactly of the problems getting the ca in yet but theres heaps of info on it on ppl doing it. As far as ive worked out so far its basicly just a small trans tunnel mod for the shifter and a new cross member which maddat make. They can actually make everything ul need for the conversion which isnt much needed. Hardest bit will be wiring i think. The ca would be a far better motor and easy for bits for prob similar sorta money since even with the l series motor ul need 2 do brakes and driveline. My cars the same as urs so if u go that route we can work together and discuss problems through the build.
Posted on: 2012/9/1 12:20
The meaning of life is not in the fridge..
Its in the shed....
I disagree. he has access to a mild L20 cheap and no wiring mods needed really for L20b. rewire alt to bypass external regulator elec dizzy too.
Petrol will be same. No efi no messy computers or surge tanks. Heaps of parts for l series out there too.
Looks stock compared to CA too
CA have their place, I think its not needed for thus project.
Posted on: 2012/9/1 12:41
I agree CAs have their place for easy hp but they arent the prettiest of engines if you care for that matter. For me they are a pretty ugly looking thing with their factory manifolding and separate square boxy rocker covers. Its like a square sharp edged engine in a coke bottle car that deserves more curves for its heart.
L20B all the way but with Z22E pistons and Z20E rods makes them rev like an L16.
Z22E rods 152.5mm pistons 32.1mm comp height 87mm diameter
Rod stroke ratio 1.773
L20B rods 145.9mm pistons 38.1mm comp height maybe 40grams more
Rod stroke ratio 1.697
The 2045cc is a common combo w/ L series crowd almost 100cc extra
Posted on: 2012/9/1 13:18
« 1 2 (3) 4 »
