diff U bolts
From sydney
hey guys
i have a borg warner diff in my 1200 ute and cant seem to find any U bolt retaining plates that suit the shock setup just wondering if anyone has had this and worked it out.
jpg  IMG_1389.JPG (69.37 KB)
9658_507769b0300c0.jpg 291X389 px
Posted on: 2012/10/12 1:52
Re: diff U bolts
From MOOROODUC. Victoria
Why are is the lower mounting for the shocker pointing to the middle of the car?
mine point to the back and the shocks mount behind the diff
Posted on: 2012/10/12 2:18
Re: diff U bolts
From sydney
Yea these ones are off a commodore and I was wondering what people have used as the standard ones don't fit around my diff
Posted on: 2012/10/12 3:43
Re: diff U bolts
From NSW, Australia
In Sydney you can call Dellow Automotive they sell the longer U bolt kits for Datto's. You can get the number on line or yellow pages.
Posted on: 2012/10/12 6:18
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
Re: diff U bolts
From Townsville, QLD
I have commo BW diff too, just go to your local suspension place and get longer/wider Ubolts. I just had to enlarge 2x rear holes in the mounting plate to get them through. Also they gave me longer/deeper nuts
Posted on: 2012/10/12 6:42
Fuel lines this week, turn the key by the weekend.....
Re: diff U bolts
From Snohomish, WA USA
Yes, U-bolts come in all shapes and sizes. Don't ask for a bolt for a specific car model at an automotive place. Just go to a bolt distributor and tell them what you want. They don't care what its for. If they have it they will get it. I got my U-bolts from Grainger Distributor and built the plates myself. Just be creative and innovative. Make it happen.
Posted on: 2012/10/12 6:58
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Re: diff U bolts
"any U bolt retaining plates that suit the shock setup"
I have just re-read your question. Have you modified the diff to suit 1200 mounting plates when you got it shortened? When I had mine shortened they also cut off all spring/shock mounts and recreated exactly as per 1200, so I used the original plates
Posted on: 2012/10/12 8:07
Re: diff U bolts
I accept commo BW animosity too, aloof go to your bounded abeyance abode and get longer/wider Ubolts. I aloof had to enlarge 2x rear holes in the ascent bowl to get them through. Also they gave me longer/deeper nuts
Posted on: 2012/10/12 8:39
Liza smith
