« 1 (2) 3 »
Re: Any SSR Mesh experts out there?
From Brisbane, QLD
you can buy barrel halves from US, Japan and Europe.
I looked into it when I thought about widening my steelies,
Ended up getting a guy to do it.
If you can find a reputable wheel widener, he should have links to getting you new barrels for them.
Posted on: 2013/1/29 0:11
71 B110
what width are you going for? 3-4" of dish is quite a wide rim, that would be an 8j.
rims of that size are still reasonable to perchance from Japan off yahoo auctions.
as someone whos been thru the rim widening game before it goes something along these lines.
purchase narrow rims... say 300 set.
purchase new rim outers - 150 a rim.
get your rims split (SSR mesh are all welded down the centre) - 10 each
get the spigot of the barrel machined to suit the SSR centre - 10 each
then if you get them welded back together, need to be polished etc... extra money there
min spend is around 1k. unless you are or have a mate who is a machinist.
These are volk mesh 13x7&8j - these could cost you as little as 800 into aus.
Posted on: 2013/1/29 0:21
Thanks guys, so the terminology is barrels & faces?
I have a set of 13 SSR's similar to what ddgonzal showed. I have flipped the faces (or the barrels depending on how you look at it) and created some nice dish but excessive negative offset. I can't afford super wide rims and tyres at the moment so I'm just checking to see if it's okay to run them reversed like I have done.
jpg  DSC01212.jpg (165.25 KB)
7952_51073cc82ceb5.jpg 1200X674 px
Posted on: 2013/1/29 3:03
From Sydney
Could make it interesting to pump up your tyres....
Posted on: 2013/1/29 3:10
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Should be fine Chris. Benny Chris loves a good reach around to,pump,and release a but of pressure
Posted on: 2013/1/29 3:30
increase the wheel track a little :)
Posted on: 2013/1/29 3:55
That is not a radical amount of negative offset -- except that Datsun 1200 has +30 positive offset stock.
I haven't heard of anyone flipping the faces. But if the flange is symmetrical I can't see how it would hurt.
Posted on: 2013/1/29 4:29
So the term 'reverse mesh' is nothing to do with what I've done but instead a description of the pattern?
I prefer dish and track without the extremely high cost of super wide wheels. Plus the rubber is difficult to find.
To remove the centres I pressed them out and to install them I froze them and then refitted them.
Posted on: 2013/1/29 4:49
Should be fine and safer than half the cars on the road up there lol
Posted on: 2013/1/29 4:54
From Sydney
polish polish polish, and they should look the business.
Posted on: 2013/1/29 5:39
1970 KB10 Coupe
S13 caliper b...
« 1 (2) 3 »
