Making an inlet gasket for CA
From Goulburn NSW
Hi guys just rang repco about some gasket paper.Apparently theres 2 different types,one normal and one with a thin sheet off metal in the centre.Which one do i need?
Posted on: 2013/1/29 6:00
Re: Making an inlet gasket for CA
Is it better to buy one perhaps? Might save you alot of hassle?
Posted on: 2013/1/29 6:37
From Goulburn NSW
Hi clyons im getting work done to the head,so the standard one wont be any good.Im getting the 8 port converted into 4 larger ports,like this.
jpg  IMG_1549.jpg (75.79 KB)
14333_510771a6b3944.jpg 648X484 px
Posted on: 2013/1/29 6:52
From Brisbane
I'd still use a standard one and just trim it back, atleast the bolt holes and the outside edges are already the right shape.
Posted on: 2013/1/29 7:13
From Goulburn NSW
So guys do i need the gasket paper with the thin steel middle,what the plan is is to buy the normal gasket copy it onto the gasket paper,then do the mods,then cut it out.
Posted on: 2013/1/29 8:00
The one with metal is not needed for non-Turbo use.
Just use gasket material of the appropriate thickness.
Posted on: 2013/1/29 8:19
From Goulburn NSW
Hi dd its a det so im guessing that i need the metal one.
Posted on: 2013/1/29 8:44
From Sydney, Australia
The surfaces are flat and even, they will only see 30 pound boost.
It's still not close to the head pressures of 200-300psi seen in the cylinder.
Just buy a standard paper gasket, trim it to suit, and correctly torque everything.
Posted on: 2013/1/29 11:18
From mandurah
yea dattodude is right ,i did that on my a15 when i ported it ,just sit the gasket over the studs on the head then dremel the inside out to suit, easy ,cheap and wont leak like a home made gasket will
plus will look 10 times neater
Posted on: 2013/1/29 12:55
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
I might have a spare gasket laying around I can probably mcdat but I won't be home for 2 weeks if u can wait that long?
Posted on: 2013/1/29 22:32
