pic of offset? 15 x 7 +0
From Melbourne, Australia
anyone running or have a pic of 15 x 7 +0 on a 1200?
thinking of buying some, just wondering exactly how they will sit
this is for my car with flares so i have some extra room out wide
Posted on: 2013/2/1 6:44
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: pic of offset? 15 x 7 +0
From Melbourne AUS
ive got 15x7 but not sure what offset. im running wider diff too so my pics wont help you much, but your welcome to
trial fit my wheels to check for offset
Posted on: 2013/2/1 6:48
1973 B110 A12
From Canberra
IVe just gone through this to determine what offset to run on the front of my race coupe.
I intend to run 225/50 tyres on a 15x7 rim.
My car is flared (50mm flares) guards are cut.
Struts are stanza cut down with either 1200 or stanza lower control arms. Hubs are stanza.
This does kick out the axle further out so keep that im mind.
The minimum Positive offset i can run is +12, anything less then that will stick out past the flares.
This offset give good clearance to coilover coils, my car will sit pretty much with the lower control arm flat so worst possible outwards movement (forgot to add this is with high camber levels of around 5 deg).
If you are going to run 195 or 205 tyres you might be able to run a lesser positive or even -ve offset.
My wheels are on order superlite GTR rims.
When the arive in a couple of weeks I can do a demo fit for you.
Posted on: 2013/2/1 7:36
From Ringwood, Melbourne, AUS
Use this to compare against a known set of wheels you already have:
http://marksink.com/tire_wheel_offset/offset.html
It will tell you how much further out the rim will sit compared to what you already have.
Posted on: 2013/2/1 7:45
Deano
From Sydney, NSW
This is 14x7 -0 on a datsun 1200 sedan with only inner lips flatened, sat flush with the gaurds :)
Posted on: 2013/2/1 15:55
Snapped crank and still smiling, How do I do it? LOL
From Sydney, NSW
with 155/55r14 federal FD1's
15x7 p8 but had 10mm spacers on aswell
And on the front with no spacers but has the bigger ball joints and 200b front end
Posted on: 2013/2/1 21:32
Car free
From south coast nsw
I have old pics in my album with some konig rewinds on 15 by 7 +-0. On a 165 .Not the best pic but they poked about an inch.
Posted on: 2013/2/3 3:43
