Source for Tulip style valves 37mm In & 30mm Ex
From Las Vegas USA
Looking for 37mm intake and 30mm exhaust valves (tulip style) 7mm stem, I recall that these may be NLA through Nissan. I have a set that I thought would be fine but they are not, it's holding up my A15 build. The standard ones from Nissan appear to be getting scarce as well.
Tom
Posted on: 2013/2/3 23:39
Re: Source for Tulip style valves 37mm In & 30mm Ex
From Sydney
Tom, There is quite a bit of used NASCAR 7mm tulip titanium valves on ebay US atm. Not very expensive either. Would need to have them cut down though.
Titanium valves
Posted on: 2013/2/4 0:50
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Freo
anyone had Joy with the titanium ones?
I bought a set of inlets (so they are massive) yonks ago,
and even some Ducati 7mm lashcaps to put on them...
just never got round to shortening and grinding them down..
Posted on: 2013/2/4 2:36
A15 PSI Project Motor
'72 CB750k,
From Sydney
Grinding is the way to go with Ti valves. Apparently they are a pain in the butt to machine in say a lathe, due to being prone to chatter.
Posted on: 2013/2/4 2:38
1970 KB10 Coupe
S13 caliper b...
Peter PJZ had some no?
Posted on: 2013/2/4 6:38
From Taupo New Zealand
Have you tried SI Valves?
Posted on: 2013/2/4 7:10
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From Las Vegas USA
Time to laugh.......all these years looking in the catalog I thought SI was some sort of abbreviation.
I called the folks at SI Valves in SoCal they had the intakes but only 2 exhaust valves, and they made 2 more exhaust valves and shipped them the same day. I should have them tomorrow..
The down side of this, not having the parts to put the head back together was going to be my excuse to run my vintage motocross bike at a off road GP on Saturday............dooh!!
Tom
Posted on: 2013/2/8 2:55
They have Nissan Competition valves in stock? Or just stock A14 valves and you will tulip them?
Posted on: 2013/2/8 2:58
From melbourne
What are the benefits of Tulip valves ?? I read somewhere that they weigh more and limit the rpm somewhat. But they give more torque.
Posted on: 2013/2/8 4:37
From Las Vegas USA
Dave these are the exact valves you'd get from Motorsports, they are made by SI. My nomenclature is, I think wrong, the valves are swirl polished and have under cut / narrowed stems near the head.
They showed up tonight and I've been out in the garage prepping the head so I can take it over to a buddies shop and get the valve job done. The seats where they match up to the port needed to be opened up about 1mm..................this is the last of thing I need to get the engine done. The short block is already I the car. I've had it apart for 3 months now and it's making me batty. I may actually have it running by Sunday.
The final tally on the motor is now at $2544, should be at least 100 RWHP hoping for the 110-115 RWHP range. The A12 was at 80 RWHP, went up to 1508cc, 12-1 compression, the 37/30 mm valves and the Delta 278 Cam. I'm pulling another 60lbs out of the car should be down to 1600lbs even. Mostly though the extra torque should be very nice, no more zinging it to 8600 RPM's in an attempt to keep up down the straights.
Tom
Posted on: 2013/2/9 7:03
