(1) 2 3 »
Nissan Heritage Collection - Sunny TS Cup specs
From Brisbane, Australia
Datsun Sunny Excellent Coupe (1973 : KPB110)
http://www.nissan-global.com/EN/HERITAGE/datsun_sunny_excellent.html
Overall length / width / height
3,995/1,515/1,355mm
Wheelbase
2,340mm
Tread (front/rear)
1,255/1,245mm
Curb weight
775kg
Engine
LZ14 (16-valve DOHC), ECGI
Engine Displacement
1,598cc (87.8 dia. x 66)
Engine Max. power
147kW (200PS)/9,400rpm
Transmission
5-speed
Suspension (front, rear)
Strut, leaf rigid
Brakes (front, rear)
Girling 4-pod, drum
Tires
205/515-13
Note:Competition car
Winner of the 1973 Japan GP (TS race)
Datsun Sunny 1200 Coupe GX-5 (1972 : KB110)
http://www.nissan-global.com/EN/HERITAGE/datsun_sunny_1200.html
3,825/1,615/1,290mm
Wheelbase
2,300mm
Tread (front/rear)
1,240/1,245mm
Curb weight
638kg
Engine
A12 (4-cyl. in line, OHV), 1,298cc
Engine Max. power
107kW (145PS)/8,500rpm
Engine Max. torque
127Nm (13.2kgm)/7,600rpm
Engine Carburetors
Solex 44PHH (x2)
Transmission
5-speed
Tires (front, rear)
7.0/21.0-13, 7.4/21.8-13
TS race specifications (1975 specification engine)
Posted on: 2013/4/30 0:34
Edited by L18_B110 on 2013/6/2 23:44:46
Edited by L18_B110 on 2013/6/2 23:45:31
Re: Nissan Heritage Collection - Sunny TS Cup specs
the rest of that site is worth a browse too.
I found it by chance this morning while googling Datsun stuff.
Posted on: 2013/4/30 0:38
PitRoad prepped B310 TS Cup specs
http://www.superstreetonline.com/featuredvehicles/sstp_1105_1974_nissan_sunny_b310_1979_nissan_sunny/viewall.html
979 Nissan Sunny B310 (#22 car)
Owner Yoshimitsu Ogura
Power 162hp @ 9100RPM, 96 lb-ft @ 8300RPM
Engine 1303cc normally-aspirated A12 engine; Pit Road Type-1 ported/polished/milled cylinder head, titantium valves, racing valve springs, guides, seals and retainers, racing push rods, hollow lifters, racing rocker arm kit, A race type camshaft, head bolts, metal head gasket, H cross section connecting rods, forged piston set, reinforced timing chain w/adjustable tensioner, racing baffled oil pan, racing pulley w/ignition pickup kit, tachometer gear box kit, 77mm bored block, oil journal expansion, racing crankshaft, racing header; Webber dual 48mm side draft carbs; Tomei intake manifold and adjustable cam sprocket; NISMO bearings, oil cap, NISMO/Earl’s oil cooler, aluminum radiator; Ultra plug wires, Ultra MDI ignition box; ATL FIA certified fuel cell; Wako gold ignition coil
Drivetrain Vintage old-stock Hewland 5-speed close ratio dog-engagement gear box; Pit Road customized TRD AE86 LSD
Footwork & chassis Pit Road full pillow ball adjustable coilover; Safety 21 12-point chromium molybdenum steel rollcage
Brakes Nissan President MK63 front brake calipers, Nissan Silvia rear caliper; custom lines and brackets by Pit Road
Wheels & tires 13X8/9" RS Watanabe original magnesium wheels; 205/50R13 front 225/50R13 rear Advan race slicks
Exterior Restored FRP front fenders, flares, doors, hatch, carbon-fiber hood; removed underbody coating; Tomei front lip and rear spoiler
Interior Sound deadening and any excess paneling removed; fire suppression system; Personal steering wheel; IMSA racing bucket seat; Willans FIA harness; Omori gauges
Full story in the above link.
Posted on: 2013/4/30 1:09
cool finds l18_B110
Also the Ts cup had different classes limited by their engine capacities.So i wonder which class the lz14 beasts ran in.
il try and look up the tomei ts cup specs too.
The Ts cup 1300cc are my inspiration for the coupe build.I love those 1300cc beasts.
Posted on: 2013/4/30 11:07
This is the TS-SUNNY Race Spec Engine.
BASE ENGINE
NISSAN A12 Type
TYPE
2 Valve, Inline 4 Cylinder, Water cooled, OHV
DISPLACEMENT
1303cc
BORE x STROKE
77.0×70.0mm
COMPRESSION
12.5:1
PEAK POWER OUTPUT
170PS (8000rpm)
CYLINDER BLOCK
A12 (From Nissan Cherry)
CYLINDER HEAD
GX Type
HEAD GASKET
TOMEI POWERED 0.8mm
CAMSHAFT
TOMEI POWERED  78°7.75
VALVE
Intake 40.0mm, Exhaust 33.0mm
VALVE SPRING
TOMEI POWERED Double Spring
VALVE LIFTER
NISMO Hollow
PUSH ROD
TOMEI POWERED
ROCKER SHAFT
TOMEI POWERED
ROCKER ARM
Modified from Standard Bush
PISTON
FORGED MMR
CONROD
Standard with WPC Treatment
CRANKSHAFT
Standard with Modified Oil Galleries
CRANK PIN BEARING
NISMO
CRANK BEARING
NISMO
OIL PUMP
Race Spec
OIL PAN
TOMEI JIDOUSHA
VALVE PLATE
TOMEI JIDOUSHA
WATER PUMP
INTAKE MANIFOLD
TOMEI POWERED
EXHAUST MANIFOLD
TOMEI POWERED
CARBURETOR
WEBER 45DCOE9
AIR FUNNEL
TOMEI POWERED
IGNITION SYSTEM
NAGAI DENSHI CDI Crank Pickup Without Alternator.
SPARK PLUG
NGK 4304A-10
PLUG CORD
NAGAI DENSHI
OIL
WAKOS Synthetic
FLYWHEEL
TOMEI JIDOUSHA
CLUTCH COVER
NISMO
CLUTCH DISC
NISMO
FUEL PUMP
NISMO
TRANSMISSION
Race Spec F56A
DIFF
NISMO H150 LSD
FRONT SPRING
CUSCO
REAR SPRING
RACE SPEC
FRONT SHOCK
TRD
REAR SHOCK
TOMEI JIDOUSHA
BUSH
JODOUSHA KOUBU HIROTA
FRONT WHEEL
TOSCO 8J-13
REAR WHEEL
TOSCO 9J-13
FRONT TYRE
ADVAN Springs 205-500-13
REAR TYRE
ADVAN Springs 225-500-13
BREAK CALIPERS
NISMO MK63 Bench Rated
BREAK PADS
LUVIX
BREAK SHOES
LUVIX
FRONT SPOILER
TOMEI JIDOUSHA
REAR SPOILER
TOMEI JIDOUSHA
ROLL CAGE
GARAGE ALTEA
Posted on: 2013/4/30 11:16
Not too shy to talk
The Nissan Heritage site is great, has some good basic information about all the classic Datsuns.
I am currently collecting all the parts to build a replica of the No. 2 Sunny Excellent pictured above. I have a 1200 coupe shell and the engine, Now I just need to try to find kpb110 front panels, tail lights and dash.
It's going to take a while but hopefully it should be a fun project and very unique and rewarding once finished.
Posted on: 2013/4/30 12:19
Just a small correct, the KPB110 displacement of 1598cc should read 87.8mm bore with a 66m stroke.
There were 2 categories i.e. TS-a and TS-b. TS-a I believe catered for up to 1600cc whereas TS-b catered for the bigger cars e.g. Skyline GT-R, Mazda Savanna RX3 etc. The TS-a class at the time was dominated by the Toyota Celica 1600 GT until the Sunny LZ engine was permitted by the FIA for use in 1973.
Posted on: 2013/6/2 15:17
I'd be very dubvious of the figures a12grunt posted of more power at much lower revs. Just doesn't stack up. That equates to 109.6lb-ft at peak power - and the peak torque would be higher again. It's simply not realistic to think they found a way to make ~20% more torque than the others.
A mistake in the quoted rpm is the most likely problem.
Posted on: 2013/10/28 1:10
Edited by L18_B110 on 2013/10/28 3:57:05
What are the compression ratios? is the TS-SUNNY Race Spec Engine from the 80s?
I remember Feral stating his Formula Atlantic A13 made 163hp and some 170hp.
I wonder what a full spec A13 with todays efi, rocker improvements, friction coatings, isotropic finishing, roller cam setup and other technology could make?
There is 775kg vs 638kg for LZ vs A series thats 137kg difference!
would that be just the running gear?! donk, suspension, brakes, box and diff?
Posted on: 2013/10/28 2:52
sigh. So much for having a realistic A series horsepower thread...
real world examples of the best full race A series engines from credible sources and people still want to imagine how much more they could make 'if only'...
Posted on: 2013/10/28 3:48
(1) 2 3 »
