« 1 2 3 4 (5) 6 7 8 »
Re: The awesome engine sound thread
From sydney.nsw
a12 stroker, a14 internals; http://www.youtube.com/watch?v=qEM4Ie3MOxk
Posted on: 2013/3/13 23:27
Edited by bige on 2013/3/14 5:14:20
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
nice a12 stroker A14 crank or A15?
anyone have sounds of this?
http://en.wikipedia.org/wiki/Chrysler_IV-2220
General characteristics
Type: 16-cylinder turbo-supercharged liquid-cooled 60° inverted V aircraft piston engine
Bore: 5.8 in (147.3 mm)
Stroke: 5.25 in (133.4 mm)
Displacement: 2,219 cu in (36.36 l)
Length: 122 in (3,098.8 mm)
Width: 33.5 in (850.9 mm)
Height: 33.5 in (850.9 mm)
Dry weight: 2,430 lb (1,102.2 kg)
Components
Valvetrain: Single overhead camshaft actuating two valves per cylinder
Supercharger: With aftercooler
Turbocharger: With water-to-air intercooler
Fuel system: 1 x Bedix-Stromberg PD-16D1 2-barrel horizontal injection carburettor with automatic mixture control
Fuel type: 100/130 grade gasoline
Oil system: Pressure fed at 70 psi (482,633.0 Pa), dry sump, 120 S.U. (25.1 cs) grade oil.
Cooling system: Liquid-cooled
Performance
Power output:
2,500 hp (1,864.2 kW) at 3,400 rpm for takeoff
2,500 hp (1,864.2 kW) at 25,000 ft (7,620 m) METO
2,150 hp (1,603.3 kW) at 3,200 rpm normal rating
1,450 hp (1,081.3 kW) at 2,800 rpm cruise
Specific power: 1.13 hp/cu in (51.2 kW/L)
Compression ratio: 6.3:1
Fuel consumption: 0.42 lb/hp/hr (0.2555 kg/kW/hr)
Specific fuel consumption:
0.54 lb/(hp·h) (0.33 kg/kW/hr)) METO
0.43 lb/(hp·h) (0.26 kg/kW/hr)) normal rating
Oil consumption: 0.005 lb/hp/h (0.003 kg/kW/hr)
Power-to-weight ratio: 1.02 hp/lb (1.84 kW/kg)
Posted on: 2013/3/14 1:18
From Sydney
For non piston powered engines, I have always liked the le mans Mazda 787B machine. Quad rotor beast. sharp and responsive.
Mazda 787-B
Posted on: 2013/3/14 6:38
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
not as responsive but whats the cnc build of the engine
http://www.youtube.com/watch?v=PrhJCN2xK4U
and some more close up cruising
http://www.youtube.com/watch?v=S0kE84K9zB4
Love to have one of these in my engine bay :)
THIS IS WHY GERMANS were so ahead of the rest!
http://www.youtube.com/watch?v=S1sGzIX_mqo
Posted on: 2013/3/14 14:05
From Invercargill, New Zealand
Here's my SR20VE when we first got the Pulsar running...
http://www.youtube.com/watch?v=Ksa_TlQDuQA
Posted on: 2013/3/18 7:45
From bundy, QLD
Don't think you can beat the sound of mad Mike's rx7 at full noise, if u haven't herd it.. YouTube it lol
Posted on: 2013/4/25 11:24
"71, 1200 Sedan a.k.a- old_spool- (project)
73, 1200 Sedan
71, 1200 sedan (parts car)
89, swift gti (gone now)
90, swift gti
No words to describe it
1L turbo around the Nurb @ 7.22
http://www.youtube.com/watch?v=tmZMwk14r4c
Posted on: 2013/6/18 16:18
From mandurah
http://m.facebook.com/home.php?refsrc ... &ustart&__user=1358074455
I win haha!
Not realy , carbs need balancing so doesnt idle properly
Posted on: 2013/6/18 17:21
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Perth WA AUS
Looking and sounding good Jess!
Posted on: 2013/6/19 13:00
Datsun 1200 2Dr sedan.
From Kingsley, Perth, WA
http://www.youtube.com/watch?v=Z7YGVEMlHPs
Sounds a little angry...and corners like a house-fly
Posted on: 2013/6/20 9:13
