(1) 2 3 »
a14 turbo or 4age motor
Hey,great forum..I have a 1400 bakkie.want more power.would it be better to put a turbo on a14 motor or should I put a 4age motor in?which 1 will be lighter on fuel?I also drive a lot long distance and I dnt want the bakkie to be heavy on fuel.please help...I have a 4age motor laying at.just need to get the gearbox.I also have a small turbo to put on a14 motor.so I really dnt know what to do........
Thanks
Posted on: 2013/6/25 11:51
Re: a14 turbo or 4age motor
no replies??????
Posted on: 2013/6/25 19:06
4AGE is only 1.6 litre. With its EFI system, it will be easier on fuel than a turbo A14.
4AGE = 120 hp
A14-T = 100 to 160 hp
Posted on: 2013/6/25 21:33
Online
ca18det when fresh are amazing on fuel even with 12psi
All options will need engineering so might as well go
for the ca18det straight off or sleeve an A15 to 1775cc
but dont expect good economy unless you efi it.
Posted on: 2013/6/26 7:10
From mandurah
How many people have sleeved an a15 to 1775 D?
Ive never heard of an a series cracking 1608cc
Posted on: 2013/6/26 7:18
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
What is go economy?like 10km/l?I dnt think a a15 can be sleeved so big?
Posted on: 2013/6/26 7:25
I think the max bore on a A15 is 77mm....if you can bore a a15 to 1775 the can't you do the same withe a14 as the bores are the same??
Posted on: 2013/6/26 7:32
Online
Few people know, but there are a few! and one that shared this is Lemonhead. He has sleeved his A14/15 block to 82mm with room for 83mm for future rebuilds (his machinist saying 83mm is no problem and even full wet sleeving possible as the A series are beefie thickly cast iron nuggets). Lemonhead even went further fitting an E16 88mm crank into the a15 block to take it closer his build to 1859cc.
Using an A15 stock engine stock 82mm stroke & 133mm stock rods - Sleeve to 83mm with stock ca18det pistons 1775cc
You have to start with an 83mm bore head gasket so if anyone is interested in doing up the DXF file for me I will be very grateful with a spare gasket
either in copper or composite with stainless fire rings.
Then stock 83mm L Series or other sleeve as stepped and sized for the machine hole on the block usually 1.5 to 2mm at the base. 2 and 3 are offset machined but it doesnt matter with head chambers 2 and 3 as the bore is so large the valve position should be only 1 to 2mm difference to 1 and 4.
2023 Edit - this engine has changed owners a few times but is still around and would love to know the weight of the bottom end as
I weighed my A12 race engine with 80mm bores, honda flat top pistons/rods and customized knife edged A12 crank was just around 26kg
around 10kg lighter than stock A12 and much lighter than A14/A15 but it is all interesting to know the weights.
Posted on: 2013/6/26 8:28
Edited by D on 2023/3/1 4:54:12
Is that thread on this site?how can I find that?
Posted on: 2013/6/26 8:36
Online
82mm bores using sleeves on 2 and 3 only and offsetting towards 1 and 4
offsetting to 2 and 3 more can make 83mm thats .5mm each side extra and
we will need a 40mm steel head plate made up also to torque the block
before honing that way a perfect finish can be achieved.
LemonHead did mention 85mm is the max possibility when he measured the
82mm block he has done so Id be happy with 83 or 83.5mm bores max that
would b nice then I find my old post stating this dude was going more!
"Lemonhead is aiming for 85mm bores and 88mm e16 crank so if you thought
1796cc is the business imagine 1997cc :))) Now thats L series size with
20kg less." and very compact dimensions to boot!!
http://datsun1200.com/modules/newbb/v ... id=335600#forumpost335600
heres another post owner went to 1890cc
and also a e16 crank builder in Finland but link is broken you need
to look it up on waybackmachine.org just paste the link
http://datsun1200.com/modules/newbb/v ... =ASC&type=&mode=0&start=0
Posted on: 2013/6/26 9:12
Edited by D on 2013/6/26 9:27:33
(1) 2 3 »
