CA18DET Clutch
From Mandurah, Western Australia
Hi everyone, it has been a while.
The clutch in the coupe let me down today. Any opinions on the clutch kit below:
Ebay Clutch Kit
I would be lucky to take the car for a run every month, so cant justify a expensive kit and while the engine and box is out I want to do head gasket, rear main seal and timing belt.
So next question is what head gasket is the go for a stock motor?
Any thing else that I should consider replacing?
Cheers
Posted on: 2013/8/18 12:32
old_school's 1200 coupe
Re: CA18DET Clutch
All I can say that I bought 2 of those brand clutches for 2 different cars a suzuki 1.3 and renault 2.0 and they are too soft on the pedal with hardly any clamping pressure. Both are due for a change after only 6 months.
i would try this mob they can do a stage 2 or 3 version for very good price
eg. ca18et
http://www.ebay.com.au/itm/AUTOCOM-EC ... ories&hash=item46086fae6c
looking at the KA range maybe they can swap something or you mod your flywheel and still save money as not only more avail but ka clutch should be much stronger
stock KA
http://www.ebay.com.au/itm/AUTOCOM-EC ... ories&hash=item46086d16bd
stage 2
http://www.ebay.com.au/itm/AUTOCOM-St ... ories&hash=item53ef945fa1
stage 3
http://www.ebay.com.au/itm/AUTOCOM-St ... ories&hash=item4609812316
Posted on: 2013/8/19 2:39
Re: CA18DET Clutch
From Melbourne, Australia
What does a normal brake n clutch joint charge for a trusted exedy/prb clutch kit? wouldnt think it would be too much more than the $150 maybe $250
keep it simple and trusted brand i would think unless you have a big performance engine
Posted on: 2013/8/19 4:15
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: CA18DET Clutch
From Logan, QLD
Would not touch pbr, have had bad experiences with their driven plates failing, exedy on the other hand for a mass produced product is pretty good. Around $160 for one off ebay.
Posted on: 2013/8/19 9:44
Re: CA18DET Clutch
Cheers, looking at exedy clutch at the moment. Need to get some coin together and do a bit of maintaince on the coupe while the engine and box is out
Posted on: 2013/8/20 14:43
