From WA perth
I,am selling my engine because someone want's to buy my rolling body, the motor is a15 bore to 78mm forge JE pistons with forge ca 18 rods,turbo cam,head is a15 highly modified ,the inlets ports have been lifted and flowed to its Maxine an has big valves stainless, has roller rockers yellowterr, all stud bolts done ARP,the motor makes around 340HP.what you get with the motor is turbo garet 28/71 with custom manfold,quad throttle efi,all the pipe work for the incooler plus incooler,the dump pipe ,manfold,turbo are cermic coated,3" stainless ex.you get ems 4860 computer plus aem twin fire eniter,wireing harness. it runs on e85 at 25lb boost plus you get a gearbox 5 speed celica 2t with a dellow bellhousing,clutch is heavey duty puck cermic both in good condtion the motor only done 1500k all the best has gone in this motor an 2 years of work an research has bean done.its all ready to drop in an go for you, plus there's a big ali radiator with braided lines that go to the motor an radiator.this motor in my 1200ute plows off a lot of cars with that HP.we just had the power cruse on the weekend an it was bloody fast, all I asking is 10k for it cost 20k to build.
Posted on: 2013/10/6 15:04
