gilmer drive
From sydney
dose anyone know about gilmer drive belt setups for A series engines? i found write up about it but couldn't find a DIY?
all i really need to know is what kit i need to get?
cheers
Posted on: 2014/1/29 5:44
Re: gilmer drive
From Canberra
there is no specific kit for it - member: orange1200 did it..
its a small block chev 350 gilmer drive setup
the alternator pully fits no issues, the water pump one needs the bolt holes larger (machined so its still balanced) and the crank pully needed to be machined as well as the hole needed to be larger and for the keyway along with a new gilmer V-Belt the correct size
cost him around $280
If thats what i remember correctly for it but he did alot of the work himself..
It can certainly be done just alot of fidelling around to get it right
here is his video from ages ago
http://www.youtube.com/watch?v=8nCoqVdnboQ
there is really no real reason to do it besides no belt slip.. it can actually put more pressure on things and brake components from what others have said... i myself would love to do it just for the whirl sound i personally think its awesome and i think a fair few people would want to do it but there is no specific kit
Posted on: 2014/1/29 5:56
Re: gilmer drive
From sydney
i want it because of the whine and it looks cool, so the belt for the 350 dose not fit the a series?, where would i get the correct size?
Posted on: 2014/1/29 7:22
Re: gilmer drive
You can buy a gilmer belt in any size. See Gilmer drive.
Posted on: 2014/1/29 7:55
Re: gilmer drive
Use a 12a rotary kit the pulleys are smaller which is better, filters usually flog out the alternator and water pump
Posted on: 2014/1/29 8:25
datsun a15 ute
Re: gilmer drive
Gilmers ^
Posted on: 2014/1/29 8:26
datsun a15 ute
Re: gilmer drive
From oregon in the usa
Driven load on the belt has a flywheel effect for the engine.
As such a cog belt system would act like a solid "flywheel" and the v belt drive system would be like a viscous damped harmonic dampener.
Wider belts should make more whine, closer teeth would give a higher pitch whine.
I had a tape of turbojet whine playing on the sound system of my motorcycle, it fooled a pilot. You could do something like that. Place a weather resistant horn speaker near the engine, cut off output to the other speakers and make the engine sound like anything you want.
Posted on: 2014/1/29 17:30
Re: gilmer drive
From Wardell. NSW.
im pretty sure kemotorsport is looking at making a set for a series.
Posted on: 2014/1/29 20:06
