engine oil of choice for A-series motors ?
hey all,
been a while since the ol'1200 has had a fresh oil run through it !!
whats the oil of choice these days in the A series ?
i'm running A12, twin carbs, elec ignition and the motor revs out to 8k regularly ?
havent looked at oils for years really ?!! ahahhha
so if you have one you like could you post up
brand
weight
why you like it
cheers
Posted on: 2014/6/3 10:25
Re: engine oil of choice for A-series motors ?
From Kelmscott Western Australia
Penrite hpr30
Posted on: 2014/6/3 11:20
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
Shell either 15w40 or 20 50.... cause im cheap and its not bad. Valvoline is ok too but your spins to 8k and is balanced. Penrite should be fine
Posted on: 2014/6/3 11:21
From Sydney
Penrite HPR 30. all day every day. Both my A-series engined 1200's use it,. The A12GX street motor and the E85 burning High Comp A15.
Posted on: 2014/6/3 23:34
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
If penrite's good enough for your motors Benny then my lowly a12 should relish in the fresh lube !!
Posted on: 2014/6/4 10:15
From Coondle, WA Australia
I'm a fan of Penrite in general, but I have run 20w50 Shell with no problems. Main reason for the Shell is its dirt cheap. I even ran a 20W60 for a while when I had a really tired motor to help the old jigga along. Again Shell brand. Cheap, cheap!
Due to a recent oil issue with the VZ dunnydore, I've learnt some more about oils. In a nutshell, you will gain more benefit/engine life/better wear from changing out your oil more often than by using a more expensive oil.
As for performance applications, well that's a bit harder, but a mineral oil would be fine. If your not fussed, Shell 20w50. I have no reason to doubt that it will cope just fine.
http://www.shell.com.au/products-serv ... r-oils/helix-hx3/hx3.html
If you want to spend some more a Penrite oil of a similar weight is fine
http://www.penriteoil.com.au/products ... d_categ=1&id_viscosity=17
Synthetics/semi-synthetics for an A-Series is a waste in my opinion and unnecessary.
On a slightly different, but related issue
Most of the oil manufacturers in Australia run NetLube (or their own version).
Its an online oils application that lists the oils required for your car. Just type into Google NetLube and your preferred brand
Penrite
http://www.datateck.com.au/Lube/PenriteAus/
Castrol
http://www.datateck.com.au/lube/castr_au/
Plus others
Posted on: 2014/6/6 9:58
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
I love that shell cause its at every kmart usually $18 or $20 too
Posted on: 2014/6/6 10:04
From Malaysia
for me its even cheaper to buy lorry's 18 liter pail.
will use this in future.
Posted on: 2014/6/7 14:40
From Kuala Lumpur, Malaysia
jpg  olej-shell-rimula-r4-x-15w40.jpg (83.77 KB)
11398_5399ba64d5a3d.jpg 630X810 px
Posted on: 2014/6/12 15:31
Penrite hpr30 period
Posted on: 2014/6/13 0:32
