Turbo setup, how not to.
From Perth WA AUS
Posted on: 2014/6/11 13:37
Datsun 1200 2Dr sedan.
Re: Turbo setup, how not to.
If he had steel pipes accross the top so they werent sucked in under vaccum of engine would be not too bad. Messy but effective im sure.
Posted on: 2014/6/11 14:02
From MOOROODUC. Victoria
Those pipes across the top are like lungs ....let you see it breath (or choke!)
Posted on: 2014/6/12 6:45
Posted on: 2014/6/12 7:46
He's got a running turbo A-series, something most of us don't have.
Just needs a bit of change
Posted on: 2014/6/12 7:52
From Perth WA AUS
Good use of a fire extinguisher though!
Posted on: 2014/6/12 9:24
From Christchurch NZ
My supercharged A15 has short (Like 3-4inch) Silicon hose joiners connecting the Blower discharge manifold to the intake runners. When firing up it's most recent incarnation, I noticed that the intake pipes were dilating on boost, and contracting on over-run. I cured this by placing even shorter sections of pipe the same OD as the rest of it was made from. With an extra hose clip in the centre. Fixed the problem a treat.
Posted on: 2014/6/14 8:18
Forced Induction!
These are variable adjustable intake runners
ghetto style and probably more effective than
Toyotas which where ditched on big port 4age.
smaller runners are better at idle great vid!
Posted on: 2014/6/15 1:36
From Canberra
here is the video of how he made it
https://www.youtube.com/v/watch?v=cZwbxhvREK8
Posted on: 2014/6/15 3:13
Very nice manifold design
Posted on: 2014/6/15 4:00
