« 1 ... 58 59 60 (61) 62 63 64 ... 97 »
Re: Super Bee KA24DR Mod
From Snohomish, WA USA
I could redo it. The hardest part was the cutting to fit it in the dash. The gauges could be a little closer together.
Posted on: 2014/11/28 1:26
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Well.
1. Fuel Pressure
2. Air Fuel Ratio
3. Trans. Temp
4. Voltage
5. Fuel Level
6. Engine coolant Temp
7. Oil Pressure
I put the ones in the right because I'm use to seeing them on the right.
I may take D's advice and move them in a little closer.
Posted on: 2014/11/30 16:38
'73 2 Door Sedan
Scrapping the last panel and already started another one. Bring gauges in closer and all within view. Will post another photo.
Posted on: 2014/12/3 20:23
'73 2 Door Sedan
So I made a new panel. One that I can see all the gauges through the steering wheel so now all gauges are on the panel except for my tach which will remain on top of the dash. Still working on wiring. Total Chaos.
I mounted bolts on the clutch of my supercharger so now its fixed. If it was ever slipping, it wont slip now.
And lastly, I scored on a nitrous fill station. $200 for the tank and pump. I bought it from the guy that is building my adaptor plate for my Powerglide transmission. He's been busy but says hopefully later this week. He's also going to build me a bigger crank pulley for my supercharger. Will go from 6 inches to 7. So at 7000 rpms, that will max out the rated rpms on the supercharger at 14,000. Hopefully my boost will increase to 10 psi.
For now Ill keep plugging away on the wiring. Almost done. Will be nice and neat soon.
jpg  IMG_20141206_110234_860.jpg (169.04 KB)
39_5485e16db94d0.jpg 816X459 px
jpg  IMG_20141207_211327_561.jpg (175.69 KB)
39_5485e181033a1.jpg 816X459 px
jpg  IMG_20141207_211618_080.jpg (152.71 KB)
39_5485e18b135a1.jpg 816X459 px
jpg  IMG_20141207_211227_341.jpg (141.43 KB)
39_5485e1abae30f.jpg 459X816 px
Posted on: 2014/12/8 17:36
'73 2 Door Sedan
Did you put your hands on the wheel to make sure they don't obstruct your view of the guages? I forgot that With my tachometer last time
Posted on: 2014/12/8 21:50
They all look pretty good.
No work on it today. I had other stuff going on.
Still need to finish wiring. Getting close.
Posted on: 2014/12/10 5:03
'73 2 Door Sedan
Looking great, excellent effort, heaps of visibility
Posted on: 2014/12/10 9:09
Couple of shots of the GM Powerglide Transmission adaptor plate on the mill and the KA bell housing.
My friend just got around to fabbing it. Its been a busy month.
Finishing up my wiring so gauge cluster should be installed soon just in time to start modifying my trans. tunnel. Looking forward to another finished project.
jpg  IMG951828.jpg (187.37 KB)
39_548fa9a016916.jpg 1200X1600 px
jpg  IMG951829.jpg (167.56 KB)
39_548fa9b67198c.jpg 1200X1600 px
Posted on: 2014/12/16 3:47
'73 2 Door Sedan
Finished and it looks good!
Picking it up tomorrow.
jpg  IMG_4564.jpg (153.67 KB)
39_5490e9b8e51b3.jpg 1200X1600 px
jpg  IMG_3337.jpg (161.10 KB)
39_5490e9de019c7.jpg 1200X1600 px
Posted on: 2014/12/17 2:27
'73 2 Door Sedan
Finished project????!!!!
you will be part of the small group that do!
Cause unlike 99% datto owners including me
I had to make up a quote to realise.....
"You can never finish a Datsun - Xcept on the Finish line"
Posted on: 2014/12/17 3:17
