Windshield weatherstrip for coupe, where have you sourced?
From Las Vegas USA
OK my windshield weatherstrip is beat and the windshield place doesn't want to put a new one in without it citing liability issue ( it's a race car dork)......anyway I have found them Datsunlandsocal has them albeit the ones from Thailand. New-Datsun-Parts has them but looks like Ute only (listing says all but that can be right). More available from Bprojects and some places in Aus but I am trying to make an event in two weeks.
Tom
Posted on: 2015/2/22 20:08
Re: Windshield weatherstrip for coupe, where have you sourced?
Yes ute. Because there are still a lot of them in japan. It also fit sedan.
The Thai ones are supposed to be good.
Posted on: 2015/2/22 22:41
From Las Vegas USA
Dave I should clarify; the listing says fits coupe, sedan & ute..........sedan and ute yes but the same one won't fit a coupe..........correct?
Tom
Posted on: 2015/2/23 2:37
I was wondering about that. Nissan sold different seal for the Coupe windshield, but maybe the difference is small enough so it doesn't matter. Coupe windshield is about 1/4" shorter.
Posted on: 2015/2/23 2:58
From Sydney
The difference is significant. due to the coupe windscreen being laid back further when compared to the sedan/ute/wagon. the screen is physically taller shorter. The windsheild rubber has longer shorter sides. Cutting outt he extra length may be an option. sharp knife and rubber type superglue.
Edit. Yep stand corrected. The coupe screen is shorter. Just measured my car in the shed. 20.5 in top to bottom. Therefore Tom should be able to use the sedan/ ute/ wagon weatherstrip and shorten it to suit.
I knew one screen was longer than the other, just forgot which one....
Posted on: 2015/2/23 5:14
Edited by benny on 2015/2/23 8:36:10
Edited by benny on 2015/2/23 8:38:00
Edited by benny on 2015/2/23 8:42:09
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Cambria, California
Tom - I couldn't find OEM front & rear glass gaskets when I painted the coupe, so I took a gamble and sourced them from Thailand. The front fit, but the rear was so far off as to be pointless. I laid the rear glass in on the pinch weld with a bead of black silicone then filled in the gaps after it had set in place. The front went in OK, but the material is c**p. Even though the car is garaged, the corners have dried out and cracked very badly, like it was sitting in L.A. smog in a Pico Rivera backyard for 22 years. I'll fill in the cracks and gaps with black silicone, but for the price, the Q.C. just ain't there. I did see an OEM gasket a couple of days ago on fleabay, but it was in the $200 asking range.
Posted on: 2015/2/23 6:18
Thai gaskets vary in quality, from very good to very poor. The ones Datsunlandsocal sell ... I'll let you search for reviews on it. The ones on ebay have seller reviews in place.
If you use 3M brand automotive window silicone, you won't have any problems, even after 20 years.
Posted on: 2015/2/23 7:12
due to the coupe windscreen being laid back further when compared to the sedan/ute/wagon. the screen is physically taller. The windsheild rubber has longer sides.
I've never measured the coupe glass personally, but I've been told:
* Coupe differs from all others (20.5 inches ~52.1 cm top to bottom)
* Truck reportedly same as sedan (53cm top to bottom)
A guy sent me these photos of a windshield he fitted to his ute
corners differed
height was shorter
Although my sedan & ute glass were the same height
Posted on: 2015/2/23 7:33
From Sydney
Yep can confirm the coupe screen is the measurements quoted above. I had updated my original post
Posted on: 2015/2/23 8:43
1970 KB10 Coupe
S13 caliper b...
Not too shy to talk
From Portland Oregon
Nissan list a coupe W/S gaskets as 72610-H1801 but, supersedes to 72610-H1001 which is Sedan W/S gasket part number. I bought front W/S gasket from Scott's Old Rubber 5 years ago. It fit perfect, has NOT shrunk, split, bled or leaked- it's quite nice!
Posted on: 2015/2/23 14:18
