The Ford TBI was my first pick. For being easy to get and an adaptor probably not too hard to get or make. But getting a boost hose to seal on the top would be a real pain! The X3 Exel TB's are dime a dozen, easy to adapt and seal a boost hose into the top. EDIT: On further investigation they only run 15Psi and are renown for leaking. Think i'll give these a miss.
RC, I did some googling and the Starion was also TB injection. I cant find a pic of just the TB yet. As you say, They could be a bit hard to find in large numbers.
EDIT: ive found some pics, they look simple enough. They have a very large base tho.
I also just had a look at some Motorbike TB's. Like the early GSXR 750 units. I did think that you could make 4 from one set. They do have the injector bosses built in, but mounting them and rails/regs would still be a pain and only one would have a TPS.
I think i'm sticking with the Hyundai TB's for now.
I've updated the build thread with the new, easy to make FPR bracket.
http://datsun1200.com/modules/newbb/v ... id=465340#forumpost465340
