« 1 ... 19 20 21 (22) 23 24 25 ... 49 »
Re: Turbo EFI A12 for under $1200. Discussion thread
From Ballarat Victoria
Some pics just to keep things interesting.
The first pic shows the fuel return line using the original carb feed line. The std fuel pump will have to be bypassed. Or remove all these original metal lines and run hose from the FPR straight to the original hard line on the firewall.
The relays have fuses mounted in the top of them to save mounting extra fuses. Just saves a bit of wiring. The fuses are not fitted in the pic.
jpg  IMGA0173 resize.jpg (66.61 KB)
6746_553b304f76ec3.jpg 576X324 px
jpg  IMGA0174 resize.jpg (64.34 KB)
6746_553b306ba7c1e.jpg 576X324 px
jpg  IMGA0175 resize.jpg (63.59 KB)
6746_553b30783a6b5.jpg 576X324 px
Posted on: 2015/4/25 7:13
VIC DYNO HIRE
I ended up removing the standard steel fuel line around the front of the valve cover. Both the feed and return lines now follow each other behind the engine. Just flipped the FPR up the other way so the line points toward the rear. looks a touch neater.
The injector finally arrived!
Had to make a cable bracket.
Also an updated pic on the ECU panel. Still need to wire up the module when the right one arrives.
jpg  IMGA0178 resize.jpg (57.21 KB)
6746_55431e849eb4f.jpg 576X324 px
jpg  IMGA0179 resize.jpg (63.58 KB)
6746_55431e99c3fad.jpg 576X324 px
jpg  IMGA0176 resize.jpg (58.50 KB)
6746_55431eaa185a8.jpg 576X324 px
jpg  IMGA0180 resize.jpg (64.40 KB)
6746_55431ec3bf6dc.jpg 576X324 px
Posted on: 2015/5/1 7:36
VIC DYNO HIRE
From Creswell, Oregon USA
Giddy like a little school girl :D
Posted on: 2015/5/1 18:31
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
Sikyne,
Your work is nothing short of inspirational!
Your race car would have a cult following in japan.an A12 turbo powering a championship car in under 2 liter class is beyond words...
Well done and keep it up
Cheers
Posted on: 2015/5/4 10:59
heres one to improve upon using the stock air filter look :)
https://www.youtube.com/watch?v=5OxJToO0Mu4
Posted on: 2015/5/4 14:08
Wow whats the sound crushing the microphone on the camera? Sounds really bad.
Shouldn't be too hard to produce a better looking and functioning version of that.
Posted on: 2015/5/5 15:14
Parler @MDMachine
yeah cant believe it if in fact they are using the stock carb!
Posted on: 2015/5/6 13:40
Sorry guys, it's going to be a couple of weeks before I get back onto this. Just had a couple of other jobs come in.
Posted on: 2015/5/7 2:35
VIC DYNO HIRE
Been playing with this project again. Finished off the wiring today. I hope I don't have to make any changes cos I've covered it all with heat shrink.
With a bit of luck, I'll have it running and tuned tomorrow!?!
Posted on: 2015/5/18 14:47
VIC DYNO HIRE
Excitement!!!
Cant wait.
Posted on: 2015/5/18 14:58
Parler @MDMachine
